hscrugby
Joined: 12/25/2006 From: raleigh, NC, USA Status: offline
quote:
ORIGINAL: Allstar DF37 I think the blades would be alright if they were just a little bit thicker. Check to see if your flybar is hitting your bottom blades it doesn't seem like it will reach but it does. I shortened my flybar and lightened the weights on the end but you could always bend your flybar up some on the ends if you don't want to cut it. Now my bottom blades only break when I crash into myself and other things. Oh yea, that is definitely a "contributing factor" Every catastrophic wreck I've had, the little clip, holding that in place pops, off, so it flops off to the side and down, hitting the lower rotors. I didn't want to try and "enhance" that clip holding it tighter, because the blades seem cheaper, and easier to fix than something else that might break if that clip doesn't release? Does yours pop off much? It never pops out from normal flying, (well, it may have on the last one? I don't know what caused it, was flying along normal, then all of a sudden, it did like a half barrel roll, and fell straight down. I was hovering, and then going side to side so the rotors were leaning a lot. {like the "rock and roll" portion on Radd's school thingie. Only not as extreme as he does }) Cheers
