RE: E-SKY LAMA 2 THREAD
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> RE: E-SKY LAMA 2 THREAD
Page: <<   < prev  37 38 [39] 40 41 42 43 44 45 46   next >   >>
Login
RE: E-SKY LAMA 2 THREAD - 1/6/2007 7:43:02 AM
makatron
Status: offline
i got my lama 2 weeks ago from ebay, it was brand new but seems like el cheapo parts that comes in the bird need to be replaced for some first class ones asap, the blades are too weak tho
is it just me or the lama V4 looks just like the Blade CX ???
_____________________________
I fly................therefore i exist
The more you Crash........more you wanna mode your bird
(in reply to up4speed)
       Post #: 951
RE: E-SKY LAMA 2 THREAD - 1/13/2007 5:58:41 AM
fett
Status: offline
After various crashes and repairs, my E-SKY lama 2 now spins around and around when I give it power and take off. I'm not sure if it's the motor, the 4 in 1, or a problem with the inner shaft. It seems the top blades are not giving enough counter rotation. I would think it was motor if they didn't spin at all, but the top blades do spin, just not enough it seems, no mutter how much I counter the rotation with the left stick.
I tried to replace the motor anyway and the cable on my replacement motor is too short! Won't reach the 4 in1. Ughh!
Any ideas or experience would be appreciated...
(in reply to makatron)
       Post #: 952
RE: E-SKY LAMA 2 THREAD - 1/24/2007 8:57:00 PM
VinceHerman
Status: offline
quote:
ORIGINAL: gateway1234567
Disclaimer: I don’t work for nor have any relationship with Hobby Lobby, just giving credit when credit is due!
Yeah, except that all four of the posts you made say the exact same thing. Looks like SPAM. Smells like SPAM. Must be SPAM.
(in reply to rduenas)
       Post #: 953
RE: E-SKY LAMA 2 THREAD - 2/5/2007 7:02:34 AM
vega2614
Status: offline
My Lama has been working great except for a few problems I've been encountering every so often. Firstly, pretty much every time I crash now I either completely or partially break the flybar holder. I am aware of the aluminum inner shaft upgrade, but does anyone know of any downsides to getting that? I have gone through 3 inner shafts already, because I'll crash once every five flights or so, but the crashes usually lead to damage because I'm doing something high risk.
Which leads me to my next concern, and I've read about other people having the same issue. When I am doing "stunts" with the Lama, like quick cuts from full forward and then a 180 degree turn, the chopper will just completely lose all stability and start crashing towards the ground sideways. I've tried to recover, but I never succeed because the lama's at like 45 degrees from level. Does anyone know why it does this and how to prevent it (besides not doing "stunts" ? I'm guessing the stabilizer bar must collide with the top rotor due to the quick change in direction, but I'm not sure.
Finally, I seem to get some trim drift, which from what I've read from other posts, is normal. I'm somewhat surprised that swashplate trim changes mid-flight, as opposed to yaw trim (which is due to changes in chopper characteristics during flight, like battery voltage and temp). I'll have to adjust it every once in a while to have the chopper hover without lateral movement. Anyone else get this? I'm guessing it's because the lower rotor or servo clips aren't centered so the chopper is continually trying to stabilize. Thanks.
(in reply to VinceHerman)
       Post #: 954
RE: E-SKY LAMA 2 THREAD - 2/5/2007 9:54:04 AM
ccpmheli
Status: offline
Hello vega2614, I have noticed the strang behavior you mentioned a couple of times., Once I was a little panicy and pulled hard back on the cyclic to avoid an obstacle, as the heli was transitioning from forward to my rearward, it just seems the whole thing quit flying, turned on it's right side and hit the ground. No damage to the blades or flybar. The second time was in my living room, flying close to the floor and I was getting kind of close to where one of the cats was sleeping, again, I pulled hard(but not crazy hard) for rearward cyclic, again the heli just quit flying and flopped over on its right side. Its almost like the rotor blades are stalling for some reason, because the heli is going along fine(motors spinning, blades turning), and then over control pushes the blades past their stall angle, they stall, it falls. I would think these low speed airfoils would be sensitive to a high angle of attack. I guess there could always be a control problem with the 4-N-1 or TX, but to me, it sounds like everything should sound. You can hear a glitch in my Esky HB. It has only happened a few times, but you could hear the motor(s) cut off and cut on when it happened(kind of like the airplanes in movies when they are having engine trouble...AnnnN.....AnNn.AnnNN), even though it only lost 6" of altitude, before recovering. From my limited experiences with coaxial rotored helis, they have very little control authority on the cyclic, considerably less than even a fixed-pitch standard heli. Though that makes them easier to manage for the beginner, it takes away the maneuverability, and significantly reduces the ability to get out of sticky situations. As far as your trim comments go, I know that the smaller area I fly it in, the quicker it becomes effected by it's own turbulence, and the more severe the effect. I don't know what is happening in your case, but I thought I would say that. You said you were breaking the center shaft, I have not broken one yet, including a crash from about 10 feet. However, I have broken 3 of the bottom blades. One rule I have, is if I know I am going to crash, I chop the throttle immediately. I realize this is harder to do when you are flying "edge of the envelope" maneuvers. I do not believe it is possible for the stabiliser bar and the upper set of blades to meet as long as they are attached, as they are turning on the same shaft. I also do not believe either of them could contact the lower blades(they would have to flex a whole bunch)I have heard people report that they think their stab bar came off in flight, that would certainly cause a loss of control, but in both of the cases I mentioned above, my stab bar was in place. Good Luck.
Just wanted to add this comment. These helis fly with a relatively low rotor speed, that coupled with the ease of the blades to swing on their mounting bolt(lead-lag), and their high drag airfoils, might be contributing to the problem. I theorize, that when a sudden increase in throttle occurs with an extreme control input, the advancining blades lag on the acceleration of the shafts/rotor heads, that coupled with the low speed, high drag airfoil casues the blade to lag even farther, leaving the blades at such an extreme angle off of center, that the blades quits supporting their side of the rotor disc, as the effective length of the advancing blades is reduced. Also A stalling of the advancing blades would be likely.
< Message edited by ccpmheli -- 2/5/2007 10:07:48 AM >
Remember the old saying, "Helicopters don't fly, they beat the air into submission.".
(in reply to vega2614)
       Post #: 955
RE: E-SKY LAMA 2 THREAD - 2/7/2007 3:55:01 PM
jav3
Status: offline
Hello everyone...I've had my Lama V2 since Christmas and it's been a great heli to learn on since I was new to helis. I'm experiencing a problem now and wanted some advice without having to go thru 39 pages. Here's my problem:
I'm experiencing loss of altitude after flying for a couple of minutes. I've noticed that the 4-in-1 goes red while it's dropping. I then land, throttle down and then start back up only to have it happen seconds later. I'm thinking it's either the motors overheating or the battery isn't fully charging.
Any suggestions? Thank you in advance!
(in reply to ccpmheli)
       Post #: 956
RE: E-SKY LAMA 2 THREAD - 2/7/2007 4:18:36 PM
vega2614
Status: offline
Sounds to me like the battery isn't fully charged. I believe that red light indicates the motors are requiring more voltage than the battery can handle. I usually land when only a slight increase in altitude throttle yields the red light. You know that soon enough the chopper will fall to the ground. Of course, it could always be the motors working inefficiently as well. Maybe try a new battery first (you'll want one eventually anyways)?
(in reply to jav3)
       Post #: 957
RE: E-SKY LAMA 2 THREAD - 2/7/2007 9:41:08 PM
J-Cube
Status: offline
If you're guessing about what your lipo's battery voltage is at, you should get an LGG-1 from www.techmodelproducts.com
Otherwise, your lipo could stop working or catch on fire.
Cash is crash without the r.
       Post #: 958
RE: E-SKY LAMA 2 THREAD - 2/8/2007 12:43:40 AM
ct420
Status: offline
quote:
ORIGINAL: jav3
I have encountered this problem twice with my Lama. Each time was for a different reason.
1) The E-sky lipo that comes with the Lama is junk. It can not tolerate ANY abuse whatsoever. If you have ever discharged it too far even a little, then it is likely dead. This happened to me with 2 batteries. I had discharged them both a bit too far once or twice, then they started doing what you described. I could take off, and fly normally for about 1 minute, then there would be a sudden loss of power. If I land for a few seconds, the cycle woud repeat. This is most likely your problem, but if not, then:
2) I have found that if you have a mechanical problem that causes the motors to 'work' too hard, this can happen. Check to make sure all bearings, shafts, etc. are good, and that the gears aren't rubbing on the frame, etc.
If it does turn out to be your battery, then I suggest you replace it with something better. You can find MUCH better batteries that fit the Lama here:
http://www.techmodelproducts.com/lama.php
Look for the red after-market lipos near the bottom of that page. I've had two of these batts for several months now, and they are still going strong. Highly recommended!
Also, to avoid problems like this in the future, be sure to stop flying AS SOON as you notice that it takes a little more throttle than normal to hover. Or, get a lipo alarm to be extra sure you don't drain the battery too far.
(in reply to jav3)
       Post #: 959
RE: E-SKY LAMA 2 THREAD - 2/8/2007 9:47:06 PM
jav3
Status: offline
I tried flying today but after about a minute, the red light came on and the heli starting dropping. I'll get another lipo to see if that's the case. It will be nice to have two lipos anyways. I appreciate the information.
(in reply to ct420)
       Post #: 960
RE: E-SKY LAMA 2 THREAD - 2/9/2007 4:24:56 PM
CCbusa05
Status: offline
Hi guys! Haven't been on this site in a while. I hope the following will help some of you out! gotta love these Lama V2/3s!
http://www.rcgroups.com/forums/showthread.php?t=638454
AND
http://www.rcuniverse.com/forum/m_4167924/anchors_5393409/mpage_1/key_/anchor/tm.htm#5393409
< Message edited by CCbusa05 -- 2/9/2007 4:26:31 PM >
(in reply to jav3)
       Post #: 961
RE: E-SKY LAMA 2 THREAD - 2/14/2007 5:13:06 AM
davidm
Status: offline
My E SKY Robbins has the wobbles and shakes after it hit a table at slight throttle. Its so bad I wont fly it. Is their a way to figure out if its the inner shaft or the outer shaft? The sway bar looks straight.
I see the parts interchange with the LAMA.
DavidM
(in reply to BadBoy__MadMikey)
       Post #: 962
RE: E-SKY LAMA 2 THREAD - 2/14/2007 7:10:47 AM
tkris
Status: offline
A tip I read on one of the lama threads.. Take off the blades, and slowly increase the throttle with the rudder all the way to one side or the other.. that should cause just the inner or outer shaft to rotate up to about 1/2 throttle, which should be plenty for you to see which shaft is out of true.
Good luck getting your heli back in the air.. it sucks to be grounded.. :/
(in reply to davidm)
       Post #: 963
RE: E-SKY LAMA 2 THREAD - 2/17/2007 12:02:44 AM
ct420
Fro
