RE: E-SKY LAMA 2 THREAD (Full Version)
All Forums >> [RC Helicopters] >> Electric RC Helis >> Esky Helicopters
Message
makatron -> RE: E-SKY LAMA 2 THREAD (1/6/2007 7:43:02 AM)
i got my lama 2 weeks ago from ebay, it was brand new but seems like el cheapo parts that comes in the bird need to be replaced for some first class ones asap, the blades are too weak tho
is it just me or the lama V4 looks just like the Blade CX ???
fett -> RE: E-SKY LAMA 2 THREAD (1/13/2007 5:58:41 AM)
After various crashes and repairs, my E-SKY lama 2 now spins around and around when I give it power and take off. I'm not sure if it's the motor, the 4 in 1, or a problem with the inner shaft. It seems the top blades are not giving enough counter rotation. I would think it was motor if they didn't spin at all, but the top blades do spin, just not enough it seems, no mutter how much I counter the rotation with the left stick.
I tried to replace the motor anyway and the cable on my replacement motor is too short! Won't reach the 4 in1. Ughh!
Any ideas or experience would be appreciated...
VinceHerman -> RE: E-SKY LAMA 2 THREAD (1/24/2007 8:57:00 PM)
quote:
ORIGINAL: gateway1234567
Disclaimer: I don’t work for nor have any relationship with Hobby Lobby, just giving credit when credit is due!
Yeah, except that all four of the posts you made say the exact same thing. Looks like SPAM. Smells like SPAM. Must be SPAM.
vega2614 -> RE: E-SKY LAMA 2 THREAD (2/5/2007 7:02:34 AM)
My Lama has been working great except for a few problems I've been encountering every so often. Firstly, pretty much every time I crash now I either completely or partially break the flybar holder. I am aware of the aluminum inner shaft upgrade, but does anyone know of any downsides to getting that? I have gone through 3 inner shafts already, because I'll crash once every five flights or so, but the crashes usually lead to damage because I'm doing something high risk.
Which leads me to my next concern, and I've read about other people having the same issue. When I am doing "stunts" with the Lama, like quick cuts from full forward and then a 180 degree turn, the chopper will just completely lose all stability and start crashing towards the ground sideways. I've tried to recover, but I never succeed because the lama's at like 45 degrees from level. Does anyone know why it does this and how to prevent it (besides not doing "stunts")? I'm guessing the stabilizer bar must collide with the top rotor due to the quick change in direction, but I'm not sure.
Finally, I seem to get some trim drift, which from what I've read from other posts, is normal. I'm somewhat surprised that swashplate trim changes mid-flight, as opposed to yaw trim (which is due to changes in chopper characteristics during flight, like battery voltage and temp). I'll have to adjust it every once in a while to have the chopper hover without lateral movement. Anyone else get this? I'm guessing it's because the lower rotor or servo clips aren't centered so the chopper is continually trying to stabilize. Thanks.
ccpmheli -> RE: E-SKY LAMA 2 THREAD (2/5/2007 9:54:04 AM)
Hello vega2614, I have noticed the strang behavior you mentioned a couple of times., Once I was a little panicy and pulled hard back on the cyclic to avoid an obstacle, as the heli was transitioning from forward to my rearward, it just seems the whole thing quit flying, turned on it's right side and hit the ground. No damage to the blades or flybar. The second time was in my living room, flying close to the floor and I was getting kind of close to where one of the cats was sleeping, again, I pulled hard(but not crazy hard) for rearward cyclic, again the heli just quit flying and flopped over on its right side. Its almost like the rotor blades are stalling for some reason, because the heli is going along fine(motors spinning, blades turning), and then over control pushes the blades past their stall angle, they stall, it falls. I would think these low speed airfoils would be sensitive to a high angle of attack. I guess there could always be a control problem with the 4-N-1 or TX, but to me, it sounds like everything should sound. You can hear a glitch in my Esky HB. It has only happened a few times, but you could hear the motor(s) cut off and cut on when it happened(kind of like the airplanes in movies when they are having engine trouble...AnnnN.....AnNn.AnnNN), even though it only lost 6" of altitude, before recovering. From my limited experiences with coaxial rotored helis, they have very little control authority on the cyclic, considerably less than even a fixed-pitch standard heli. Though that makes them easier to manage for the beginner, it takes away the maneuverability, and significantly reduces the ability to get out of sticky situations. As far as your trim comments go, I know that the smaller area I fly it in, the quicker it becomes effected by it's own turbulence, and the more severe the effect. I don't know what is happening in your case, but I thought I would say that. You said you were breaking the center shaft, I have not broken one yet, including a crash from about 10 feet. However, I have broken 3 of the bottom blades. One rule I have, is if I know I am going to crash, I chop the throttle immediately. I realize this is harder to do when you are flying "edge of the envelope" maneuvers. I do not believe it is possible for the stabiliser bar and the upper set of blades to meet as long as they are attached, as they are turning on the same shaft. I also do not believe either of them could contact the lower blades(they would have to flex a whole bunch)I have heard people report that they think their stab bar came off in flight, that would certainly cause a loss of control, but in both of the cases I mentioned above, my stab bar was in place. Good Luck.
Just wanted to add this comment. These helis fly with a relatively low rotor speed, that coupled with the ease of the blades to swing on their mounting bolt(lead-lag), and their high drag airfoils, might be contributing to the problem. I theorize, that when a sudden increase in throttle occurs with an extreme control input, the advancining blades lag on the acceleration of the shafts/rotor heads, that coupled with the low speed, high drag airfoil casues the blade to lag even farther, leaving the blades at such an extreme angle off of center, that the blades quits supporting their side of the rotor disc, as the effective length of the advancing blades is reduced. Also A stalling of the advancing blades would be likely.
jav3 -> RE: E-SKY LAMA 2 THREAD (2/7/2007 3:55:01 PM)
Hello everyone...I've had my Lama V2 since Christmas and it's been a great heli to learn on since I was new to helis. I'm experiencing a problem now and wanted some advice without having to go thru 39 pages. Here's my problem:
I'm experiencing loss of altitude after flying for a couple of minutes. I've noticed that the 4-in-1 goes red while it's dropping. I then land, throttle down and then start back up only to have it happen seconds later. I'm thinking it's either the motors overheating or the battery isn't fully charging.
Any suggestions? Thank you in advance!
vega2614 -> RE: E-SKY LAMA 2 THREAD (2/7/2007 4:18:36 PM)
Sounds to me like the battery isn't fully charged. I believe that red light indicates the motors are requiring more voltage than the battery can handle. I usually land when only a slight increase in altitude throttle yields the red light. You know that soon enough the chopper will fall to the ground. Of course, it could always be the motors working inefficiently as well. Maybe try a new battery first (you'll want one eventually anyways)?
J-Cube -> RE: E-SKY LAMA 2 THREAD (2/7/2007 9:41:08 PM)
If you're guessing about what your lipo's battery voltage is at, you should get an LGG-1 from www.techmodelproducts.com
Otherwise, your lipo could stop working or catch on fire.
ct420 -> RE: E-SKY LAMA 2 THREAD (2/8/2007 12:43:40 AM)
quote:
ORIGINAL: jav3
I have encountered this problem twice with my Lama. Each time was for a different reason.
1) The E-sky lipo that comes with the Lama is junk. It can not tolerate ANY abuse whatsoever. If you have ever discharged it too far even a little, then it is likely dead. This happened to me with 2 batteries. I had discharged them both a bit too far once or twice, then they started doing what you described. I could take off, and fly normally for about 1 minute, then there would be a sudden loss of power. If I land for a few seconds, the cycle woud repeat. This is most likely your problem, but if not, then:
2) I have found that if you have a mechanical problem that causes the motors to 'work' too hard, this can happen. Check to make sure all bearings, shafts, etc. are good, and that the gears aren't rubbing on the frame, etc.
If it does turn out to be your battery, then I suggest you replace it with something better. You can find MUCH better batteries that fit the Lama here:
http://www.techmodelproducts.com/lama.php
Look for the red after-market lipos near the bottom of that page. I've had two of these batts for several months now, and they are still going strong. Highly recommended!
Also, to avoid problems like this in the future, be sure to stop flying AS SOON as you notice that it takes a little more throttle than normal to hover. Or, get a lipo alarm to be extra sure you don't drain the battery too far.
jav3 -> RE: E-SKY LAMA 2 THREAD (2/8/2007 9:47:06 PM)
I tried flying today but after about a minute, the red light came on and the heli starting dropping. I'll get another lipo to see if that's the case. It will be nice to have two lipos anyways. I appreciate the information.
CCbusa05 -> RE: E-SKY LAMA 2 THREAD (2/9/2007 4:24:56 PM)
Hi guys! Haven't been on this site in a while. I hope the following will help some of you out! gotta love these Lama V2/3s! :)
http://www.rcgroups.com/forums/showthread.php?t=638454
AND
http://www.rcuniverse.com/forum/m_4167924/anchors_5393409/mpage_1/key_/anchor/tm.htm#5393409
davidm -> RE: E-SKY LAMA 2 THREAD (2/14/2007 5:13:06 AM)
My E SKY Robbins has the wobbles and shakes after it hit a table at slight throttle. Its so bad I wont fly it. Is their a way to figure out if its the inner shaft or the outer shaft? The sway bar looks straight.
I see the parts interchange with the LAMA.
DavidM
tkris -> RE: E-SKY LAMA 2 THREAD (2/14/2007 7:10:47 AM)
A tip I read on one of the lama threads.. Take off the blades, and slowly increase the throttle with the rudder all the way to one side or the other.. that should cause just the inner or outer shaft to rotate up to about 1/2 throttle, which should be plenty for you to see which shaft is out of true.
Good luck getting your heli back in the air.. it sucks to be grounded.. :/
ct420 -> RE: E-SKY LAMA 2 THREAD (2/17/2007 12:02:44 AM)
Hello group --
Video is here:
http://video.google.com/videoplay?docid=2960853108480519368&hl=en
I’ve had this little heli for over 1 year now, and it was pretty much worn out. I did a major overhaul on it the other night and threw in some upgrades at the same time. Both gears that drive the rotor shafts were the originals, and the teeth were worn down to little nubs :) I can’t tell you how many hours it has on it, but it’s A LOT!
This is an Esky Lama 2, but it now looks a lot like a v3. I replaced the landing skids/batt holder pieces with the black ones. My white one is broken. Also, I think the black looks better.
The stabilizer bar is the one that came with the heli. I cut and re-bent the ends to shorten it a bit. This makes the heli much more responsive, and it also greatly reduces the chances of a blade clash. I will post a pic of it next to a stock/unmodified one to show the difference in length.
The blades and motors are very nice. The flexible tail truss is OK. I wasn’t too impressed with it, but it does seem better than the stock one at least, and they are cheap…
It now hovers eye level at just under ½ stick. It has lots of ‘punch’, and took some getting used to. I almost flew it into the ceiling a few times when I first flew it with these mods :)
This heli has the following mods/upgrades:
1. Shortened stabilizer bar - custom made
2. Micro antenna
3. Techmodelproducts.com after-market lipo for Lama 2/3 - 2S 800mah
4. Aluminum Central hub and shaft (Purple Esky)
5. From http://www.miracle-mart.com :
- Flexible Material Tail Truss for Esky Lama V3,V2
- Xtreme 180 bearing motor (A) & (B) for Esky Lama
- Xtreme Blade for Esky Lama
Flies great! No more blade clashes, and almost too much power. Can fly for 10-12 mins with gentle flying or about 8-10 if pushing it hard.
Pics attached:
Frymire -> RE: E-SKY LAMA 2 THREAD (2/18/2007 1:33:10 PM)
Hey Folks!
I have an E-Sky Robins which is basically the same as the Lama 2/3, so I'm hoping someone can give me some advice! When I try to quickly move into forward flight, my heli is immediately losing altitude. A close look at it shows that the bottom set of blades are slowing down significantly when the swashplate is tilted in any direction, especially forward. Any thoughts?!
ct420 -> RE: E-SKY LAMA 2 THREAD (2/18/2007 11:31:23 PM)
Frymire: That's a strange problem. Off the top of my head, I would say, check to make sure that the swash plate, linkages, etc. do not push on one of the motors when it moves. If it is hitting a motor, it could be pushing it on the end, causing the mesh between the gears to become too tight, and rob power.
dpjr -> RE: E-Sky Lama 2 (2/25/2007 1:13:01 AM)
New V3 lama owner- Can i get confirmation on the correct position of the servo rev, switches on the xmitter. 4 switches should be in Norm position. ? Lama doing some squirrely things like continuing to throttle with throttle at zero and trim at zero- I have to turn off xmitter to stop the motors- thanks in advance
dp
tommie! -> RE: E-SKY LAMA 2 THREAD (2/25/2007 1:48:10 PM)
I had the same problem. The problem for me turned out to be the blades folding on me loosing lift and crashing. The blades have to be fairly tight and can't move during aggressive moves.
Make sure the blades are even for even lift as well.
Tom
quote:
ORIGINAL: vega2614
vega2614 -> RE: E-SKY LAMA 2 THREAD (2/25/2007 5:22:06 PM)
Huh, that sounds like that could be the case with mine. My blades aren't really loose, but they're certainly not tight (I can flick them around pretty easily with my finger). I'll tighten them a bit and see what happens. Thanks!
CCbusa05 -> RE: E-Sky Lama 2 (2/26/2007 3:36:04 PM)
quote:
ORIGINAL: dpjr
dp
From left to right: first two switches up, last two switches down.
jez33 -> RE: E-SKY LAMA 2 THREAD (3/6/2007 4:51:12 PM)
hi again to all.
does any one know if the "4 in 1 board " to fit the esky lama 3 will also fit the esky lama 2 ???
damn chip has blown again,, this time it was in mid flight.
think one of the motors started to draw to much from the chip..
ct420 -> RE: E-SKY LAMA 2 THREAD (3/6/2007 5:19:26 PM)
Yes, the 4 in 1 from the v3 will work. For that matter, so will the 4 in 1 for the E-flite BCX. You can take the old crystal from your E-sky 4 in 1, and put it in the E-flite 4 in 1, and it will work. I've done it.
Of course, the 4 in 1 for the E-flite BCX2 would also work, but you would need to get the 2.3ghz TX to go with it...
jez33 -> RE: E-SKY LAMA 2 THREAD (3/6/2007 5:23:04 PM)
quote:
ORIGINAL: ct420
cheers i will order the lama 3 4 in 1 now.
[sm=thumbs_up.gif]
jez33 -> RE: E-SKY LAMA 2 THREAD (3/6/2007 5:53:19 PM)
oh one more question on the lama 3 ' 4 in 1 board'
is the 4 in 1 more reliable then the 4 in 1 on the lama 2 ?
meaning can the chip take a bit more punishment ect ??
flying-llama -> RE: E-SKY LAMA 2 THREAD (3/6/2007 7:38:19 PM)
quote:
ORIGINAL: jez33
quote:
ORIGINAL: ct420
[sm=thumbs_up.gif]
Be careful. I have been told that the newer Lama 3 4in1's are NOT compatible with the older Lama 3 4in1's (more precisely, not compatible with the older Lama 3 transmitters).
So the newer Lama 3 4in1's are probably not interchangable with the Lama 2 4in1's.
I have seen some web sites sell both the newer Lama 3 4in1's and the older Lama 3 (hence also Lama 2) 4in1's:
http://www.bphobbies.com/view.asp?id=V890236
E-Sky 4-in-1 Controller Unit For Original Lama (EK2-0705) - OVERSTOCK SALE
Replacement 4-in-1 unit for Original E-Sky Lama Coaxial Helicopters manufactured before Sept 2006 $35.00
E-Sky 4-in-1 Controller Unit for Robins 22 and New Lama (EK2-0705B)
Replacement 4-in-1 unit for Robins 22 and Lama Helicopters manufacturered after Sept 2006 $51.75
Page: <<   < prev  37 38 [39] 40 41 42 43 44 45 46   next >   >>
Valid CSS!
SITE MAP!   : :   FORUM RULES
0.484375
