stuffing tub question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Scale Boating >> stuffing tub question
Page: [1]
Login
stuffing tub question - 11/16/2005 6:22 AM
jserb
Score: 100
Last Login: 7/17/2006
Status: offline
hey all!! well when i put my boat in the water a slow drip comes from the stuffing tub around the drive shaft. How do i stop this? grees?
Hide Signatures
       Post #: 1
RE: stuffing tub question - 11/16/2005 6:48 AM
green-boat
Score: 100
Last Login: 8/19/2011
Status: offline
The stuffing tube will need to filled with grease. I like using an automotive wheel bearing grease the dark brown stuff. Others like a white lithium type of grease.
< Message edited by green-boat -- 11/16/2005 6:51 AM >
_____________________________
If olive oil comes from olives, where does baby oil come from.
Hide Signatures
(in reply to jserb)
       Post #: 2
RE: stuffing tub question - 11/16/2005 10:00 AM
Deathwish
Score: 100
Last Login: 6/9/2013
Status: offline
Humm dont know what a stuff tub is but, I do know what a stuffing tube is. LOL I use plain old petroleum jelly in mine works pretty well.
Hide Signatures
(in reply to green-boat)
       Post #: 3
RE: stuffing tub question - 11/16/2005 6:04 PM
LtDoc
Score: 100
Last Login: 7/3/2009
Status: offline
jserb,
The stuffing tub/tube/box ought to have some kind of grease or oil in it to act as a seal. Whatever you use shouldn't be too 'thick', but should be non-soluble in water (makes sense, huh?). Lots of different opinions of whats 'best', so pick one you can live with (I like the grease used on fishing reels, comes in a 'pointy' tube which makes it easy to apply, cheap, readily available around here!). Another thing to check is the hull where the stuffing box goes through, make sure there's no leaks.
Have fun...
- 'Doc
Hide Signatures
(in reply to Deathwish)
       Post #: 4
RE: stuffing tub question - 10/4/2007 8:50 PM
gotahoe01
Score: 100
Last Login: 10/25/2007
Status: offline
Should the stuffing tube be glued or siliconed to the hull? I get a lot of water coming in, and not sure where.
Hide Signatures
(in reply to LtDoc)
       Post #: 5
RE: stuffing tub question - 10/5/2007 4:21 AM
yjguy
Score: 100
Last Login: 3/14/2013
Status: offline
the stuffing tube should be fixed and sealed to the hull. Used either glue or epoxy.
Tom
Hide Signatures
(in reply to gotahoe01)
       Post #: 6
RE: stuffing tub question - 10/5/2007 4:31 AM
Bauer66
Score: 120
Last Login: 8/30/2012
Status: offline
I seal my stuffing boxes with bondo, Then a brushing of Fiberglass resin on the interior seals it nicely. Makes for a strong watertight application.
Semper Fi!
Hide Signatures
       Post #: 7
RE: stuffing tub question - 10/5/2007 5:56 PM
LtDoc
Score: 100
Status: offline
gotahoe01,
Sure, the stuffing tube/box/whatever should be sealed to the hull. Except for a wanted hole, there are no 'good' holes in a boat, right? And like everything else, there's almost always more than one way of doing that. Pick the one that's best/easiest for you. If that sealant doesn't dissolve in water, doesn't 'eat' what it touches, it ought'a work fine. Who cares what it looks like... within reason!
- 'Doc
Hide Signatures
(in reply to Bauer66)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.094RCU1
