RE: Rollin' my own 50CC Yak 54
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> RE: Rollin' my own 50CC Yak 54 Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Rollin' my own 50CC Yak 54 - 11/30/2005 7:26:23 PM
SydDythers
Status: offline
Brent,
Looks I'll be doing the stringers/sheeting method. Basically, I have no idea on how to make those foam cheeks and I prefer stringers anyhow. Weight difference should be negligable if done correctly.
Cheers,
John
_____________________________
2 Transmitters...8 Glow Planes...3 Giant Scale...
1 Angry Wife......Priceless
(in reply to Brent G)
       Post #: 26
RE: Rollin' my own 50CC Yak 54 - 11/30/2005 7:39:21 PM
SydDythers
Status: offline
I will be starting the wing soon and have measured up the EF Yak's wing. Best I can tell is that it uses a NACA0013 on the root and a NACA0014 on the tip. I think I'll copy this arrangement in my scratch design since I never, ever, manged to once tip stall or snap the EF Yak. Very stable wing indeed. I considered the eppler 169 but in the end decided that I wanted to be able to do some IMAC type stuff on this bird as well and the 169 is just to thick of an airfoil.
Cheers,
John
(in reply to SydDythers)
       Post #: 27
RE: Rollin' my own 50CC Yak 54 - 11/30/2005 9:34:26 PM
Brent G
Status: offline
I am planning on going with the stringers also. It should be a little lighter. To do the foam cheeks all you need to do is make templites like you would for cutting out a foam wing. You just need to compensate for the sheeting thickness when you make the end templates.
Brent
       Post #: 28
RE: Rollin' my own 50CC Yak 54 - 12/1/2005 12:39:42 AM
SydDythers
Status: offline
Ha, that would make sense to me if I knew how to cut foam wing cores! Brent, I just purchased the compufoil3d program but am dissapointed that it doesn't have naca0013 or 0014. I didn't purchase the modification module and I was wondering if you were able to make a .cor of those to and send them to me?
OOOPS stupid me, I did buy the naca generator module....forget my request
Cheers,
John
< Message edited by SydDythers -- 12/1/2005 12:42:41 AM >
       Post #: 29
RE: Rollin' my own 50CC Yak 54 - 12/1/2005 1:11:47 AM
Brent G
Status: offline
I have the modification module with mine. I just modify the airfoils to what ever spec I need.
Brent
       Post #: 30
RE: Rollin' my own 50CC Yak 54 - 12/1/2005 2:27:56 AM
SydDythers
Status: offline
Hey brent, do you know how to export a 3D .dxf with not only the rib templates but also showing the stringers, LE spars etc...? Is it possible or can I only export the templates?
Cheers,
John
       Post #: 31
RE: Rollin' my own 50CC Yak 54 - 12/1/2005 12:05:03 PM
Brent G
Status: offline
John
I am not sure if that is possible. With the dxf module I can import the ribs and planform into my model cad software. If you give Eric Sanders a call at compufoil I am sure he will be able to answer your question. He has helped me several times in the past. Great customer service!!
I am waiting on some new cad software. I orderd design cad max 14. It looks like it should serve my needs. The price on e-bay was right, $16.99. If it doesn't work like I need at least I am not out a lot of money.
Brent
       Post #: 32
RE: Rollin' my own 50CC Yak 54 - 12/1/2005 8:46:38 PM
SydDythers
Status: offline
Put an email in to Chris and am waiting for a reply. I managed to make my own stringers. Here is the latest progress...starting to look like the innards of a yak!
Cheers,
John
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 33
RE: Rollin' my own 50CC Yak 54 - 12/2/2005 1:10:21 AM
Brent G
Status: offline
I just got my design cad software. This should be fun. I am used to doing things 2D, I am finding out that 3D is totaly diferent. Any tips on where to start would be greatly appreciated. I tried using my other drawings to build the 3D model from, with no sucess. It looks like I am on the steep part of the learning curve once again.
Brent
O-buy the way. The plane looks great!
       Post #: 34
RE: Rollin' my own 50CC Yak 54 - 12/3/2005 1:07:56 AM
SydDythers
Status: offline
Brent,
I just found 3 views on the net and then used the cad program to trace the profiles. Then I built up the airplane as you can see at the beginning of this thread. I ended up finding a copy of autocad for dummies in pdf format on the net and read through that for the first couple days. It seems you and I are on opposite ends of the spectrum...I have no idea how to build a 2D set of plans!
Cheers,
John
Latest progress:
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by SydDythers -- 12/3/2005 1:09:21 AM >
       Post #: 35
RE: Rollin' my own 50CC Yak 54 - 12/3/2005 2:31:58 AM
Brent G
Status: offline
John
I am starting to get the hang of it. It sounds like I did the exact thing that you did. I found 3 views and traced them. It has been interesting learning how the 3d cad stuff works. This is my first wire frame drawing. I am just getting the feel for it. Next I will be going back and making a better to scale drawing.
Brent
Click for fullsize
       Post #: 36
RE: Rollin' my own 50CC Yak 54 - 12/3/2005 4:22:57 AM
Looper
Status: offline
Hey guys...keep up the great work. Your progress is really interesting; especially for a Yak fan like me. I would love to build one...thanks again, Looper
       Post #: 37
RE: Rollin' my own 50CC Yak 54 - 12/3/2005 5:56:01 AM
SydDythers
Status: offline
Brent...you're on your way! Acad is a beast to master and I can't think how it could get any harder than this program so if I can do it in Acad, then anyone can! It is truly 3D UNfriendly as far as I am concerned. My next project will probably be done in something other than Acad. I can say however that it forces you to be extremely precise (tolerances are within .0001 inches) and that is good.
Looper, thanks for the encouragement. This project has come a long way from when I first posted. It sure is time consuming though! I am hoping to have the cad done within a couple of weeks and have it built within a couple of months...although February is not exactly prime time for maidening an airplane in Canada I am considering getting a bunch of these kits laser cut and selling them if it flys well. I would probably provide the plans for free but am worried that I would suffer the same fate as Silver Eagle here on RCU...at least I think that was his handle...who had his katana plans sold on EBAY by somebody who ripped them off.
Cheers,
John
< Message edited by SydDythers -- 12/3/2005 6:20:39 AM >
(in reply to Looper)
       Post #: 38
