The perfect spray gun.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> The perfect spray gun.
Page: [1]
Login
The perfect spray gun. - 11/16/2005 10:43:29 AM
Flyboy Dave
Status: offline
Check out the new HVLP (high volume low pressure) paint spray gun
from Harbor Freight. Just right for hobbying. It has a 4 oz. cup, and
interchangeable nozzles lets you shoot any type of paint. Get the nice
filter/regulator to go with it, and your next paint job will be a snap.
Required air pressure: 50 psi
Air consumption: 2.1-3.2 CFM
FBD.
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
       Post #: 1
RE: The perfect spray gun. - 11/16/2005 4:49:34 PM
Weasel Keeper
Status: offline
Been eyeballing that rascal. So, I visited the store and noticed HF has a couple different models of these detail guns. Some of them are made in China and some are made in Taiwan. Just in case anyone has a preference , it might be a good idea to check country of origin.
I love it when a plane comes together.
(in reply to Flyboy Dave)
       Post #: 2
RE: The perfect spray gun. - 12/13/2005 1:42:17 AM
Kaltag
Status: offline
CHECK OUT THIS BAD BOY! INTERCHANGABLE HEADS!
Click for fullsize
Click for fullsize
(in reply to Weasel Keeper)
       Post #: 3
RE: The perfect spray gun. - 12/13/2005 11:12:47 AM
aerospot
Status: offline
"Click on picture for full size" Yea, Right!
Theyre smaller than the pics on the post!! LOL...
(in reply to Kaltag)
       Post #: 4
RE: The perfect spray gun. - 12/13/2005 11:26:10 AM
krossk
Status: offline
I've tried to use several $39 "import" detail guns over the years and every one of them has ended up in the trash can after it destroyed a paint job. (Maybe not the first on, but eventually it will) Spend the $ right up front and get the Binks detail gun. Take care of it and it will be the last gun you ever buy. I can't speak for anyone else, but in my case, you really do get what you pay for...
(in reply to aerospot)
       Post #: 5
RE: The perfect spray gun. - 12/13/2005 12:52:48 PM
Roby
Status: offline
I don't intend to cause a fuss here, but it seems to me that
depending on what material your spraying sort of drives the
equipment thats required.
Example;
I spray latex and get excellent results
with a cheap single action Badger.
Regards
Roby
(in reply to krossk)
       Post #: 6
RE: The perfect spray gun. - 12/15/2005 1:40:57 AM
N1EDM
Status: offline
KrossK,
I'm in the market for a good Binks or DeVilbiss gun. Which model Binks Detail gun did you get? Is it a Gravity feed HVLP? And, can you get rebuild parts for it?
Bob
AMA 4307 Club Saito Member #61
An expert is someone who has been doing it for 15 minutes longer than you.
(in reply to Roby)
       Post #: 7
RE: The perfect spray gun. - 12/15/2005 1:22:43 PM
daven
Status: offline
I use a very similar gun sold at menards for $25 (No regulator). It has worked well for me.
Dave Norman
klasskote.com
supertrc.com
(in reply to N1EDM)
       Post #: 8
RE: The perfect spray gun. - 12/21/2005 9:34:57 PM
Pitts S1S
Status: offline
Once you try a Sata gun you'll never go back..
Those HVLP Harbour Freight jobs are great for primer, beyond that forget it.
Not a Rep, or Sponsored.
BUT, I'm willing to be.
(in reply to daven)
       Post #: 9
RE: The perfect spray gun. - 12/21/2005 10:32:28 PM
Flyboy Dave
Status: offline
quote:
ORIGINAL: fl-copters
Well....I don't know about that. I painted the blue on my hot rod with a Harbor
Freight $15.00 detail gun. It comes down to thinning the paint correctly, adjusting
the gun correctly, and the operators technique applying the paint.
FBD.
Click for fullsize
Click for fullsize
Revver Bro #4.
(in reply to Pitts S1S)
       Post #: 10
RE: The perfect spray gun. - 12/22/2005 1:33:06 AM
N1EDM
Status: offline
Nice ride, Flyboy...
Does she have a sister?
Beautiful rod. Would love one of my own someday.
Bob
       Post #: 11
RE: The perfect spray gun. - 12/22/2005 2:21:19 AM
Flyboy Dave
Status: offline
Thanks, Bob.....no, sorry.....It's a one of a kind.
I really did paint it with this inexpensive gun, the round water trap, and the little
regulator was another 10 bucks.
FBD.
Click for fullsize
Click for fullsize
Click for fullsize
Revver Bro #4.
(in reply to N1EDM)
       Post #: 12
RE: The perfect spray gun. - 12/26/2005 1:54:39 PM
speedster 1919
Status: offline
I've been in the paint business 32 years. Perfect gun right now would be IWATA 300 GRAVITY but at $350 I don't think you guys will run out and get one. Get a small gravity feed HVLP touch up gun and you will never use the BINKS like touch up gun again....
Hey Buddy -That was the most spectacular crash I've ever seen , That rolling cart wheel with parts slinging out was cool...
       Post #: 13
RE: The perfect spray gun. - 12/26/2005 2:12:27 PM
jlkonn
Status: offline
Question about the HVLP's.
Stands for High Volume Low Pressure right?
15 years or so ago when I started restoring the Cub in my Avitar they were just starting to be talked about in Sport Aviation...the EAA magazine. Folks talked about them as though they were the second coming but the system was very expensive. If I recall correctly it wasn't only a type of gun but the "compressor" itself was part of it's success. They actually warmed the air some.
Have they changed since then and now you can use a standard compressor?
Thanks!
JLK
A goal without a plan is just a dream.
AMA 97605
(in reply to speedster 1919)
