Yak 65 inch ARF
Tower Hobbies
Logged in as Guest
  Printable Version
50 Size 3D Profile - RTF
Seller:  DAVIS300
Details:   $275.00   |  11/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> Yak 65 inch ARF
Page: [1]
Login
Yak 65 inch ARF - 11/18/2005 2:31:51 AM
rhd-RCU
Status: offline
There are no marks on the fuse for the landing gear. From a picture on line of the foam core you don't have a lot of room to play with. Also I have checked and double checked. the fuse looks like a pin cushion from poking it with an xacto knife. Without the plans it is impossible to tell how wide the hardwood motor mounts are. Can the mount area be opened up to 1 an 7/8 th inches. I want to put in the new OS 1.2 2 cycle.
RD
I would need to remove 1/8 from each side.
< Message edited by rhd-RCU -- 11/19/2005 1:45:50 AM >
_____________________________
rd
       Post #: 1
RE: Yak 65 inch ARF - 11/20/2005 3:14:18 AM
Basement Troll
Status: offline
If you look at the instructions it gives you measurements to drill the landing gear holes. It has been my experience (2 ARF's) that the hardwood blocks are a bit closer to the front of the plane than the measurements say. I would guess at about 1/4". I took a very small bit and drilled a couple of holes untill I found solid material. The gear will cover the holes. I had to open up the engine mounts a bit on my first one for a YS 120 and it seemed ok. I hope this helps.
Don
(in reply to rhd-RCU)
       Post #: 2
RE: Yak 65 inch ARF - 11/21/2005 2:11:41 PM
AFSalmon
Status: offline
Thanks Don, you are right on the money. And yes the ARFs have enough engine wood to widen for the 120s.
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes, Team OMP Captain
(in reply to Basement Troll)
       Post #: 3
RE: Yak 65 inch ARF - 11/21/2005 2:51:45 PM
rhd-RCU
Status: offline
Thanks for the info. My instructions said nothing of the placement of the holesother than using the guide holes, which are not there.
rd
(in reply to AFSalmon)
       Post #: 4
RE: Yak 65 inch ARF - 11/21/2005 3:24:59 PM
jaybo292
Status: offline
My YAK arf did not have holes either. I looked at the gallery of picts on the OMP site and drilled mine as the others looked. I also widened mine for a YS 120. Great plane. I haven`t flown it . But have seen one fly.
When you`re dumb you got to be Tough!
       Post #: 5
RE: Yak 65 inch ARF - 11/21/2005 8:00:23 PM
AFSalmon
Status: offline
Step 7 of the ARF manual says this below and includes this diagram: It could be that you may have one of the very first CD manuals that did not include the diagram. The ARFs were supposed to include the laser cut holes for the gear but after we found out they were not predrilled, I added this picture.
7. Mark the location for the main gear mounting holes using the diagram below and drill them through for the 8-32 bolts. Either use a drill press or make sure you keep the drill square to the fuselage so that both sides are identical. Drill identical holes in the main gear provided and mount using 8-32 x 2" socket head bolts and nylock nuts. Use 8-32 x 1.25" socket head bolts, regular nuts, and nylock nuts as the wheel axles for 2.5” wheels.
Click to see fullsize image.
Click for fullsize
(in reply to jaybo292)
       Post #: 6
RE: Yak 65 inch ARF - 11/21/2005 11:21:22 PM
rhd-RCU
Status: offline
rd
       Post #: 7
RE: Yak 65 inch ARF - 11/22/2005 8:32:27 PM
extratorker
Status: offline
I just got mine the other day and this diagram wasn't included. Guess I need to move mine.
       Post #: 8
RE: Yak 65 inch ARF - 11/23/2005 12:48:55 AM
4 stroken ron
Status: offline
Mine didn't have the diagram or predrilled holes either. I did the same a jaybo292, I looked at the picture gallery and guessed at it. Seems to be fine.
Ron
Click for fullsize
(in reply to extratorker)
       Post #: 9
RE: Yak 65 inch ARF - 11/23/2005 1:17:48 PM
AFSalmon
Status: offline
The diagram is a picture which you should click on the CD manual. Should be step 7 of the final assembly section. It's not a printed piece of paper in the box. If it's not on the CD then we've been burning the wrong version manual! Hope that is not true.
(in reply to 4 stroken ron)
       Post #: 10
RE: Yak 65 inch ARF - 11/24/2005 1:59:05 AM
extratorker
Status: offline
You might be burning the wrong version. Under table of contents I've got : Home,Main Assembly,Radio Gear and Balancing. Then Other photo's, video clips. Nowhere can I find any final assembly with any type of diagrams. When I click on the pictures,all I get are enlarged versions.
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
