RE: 4*120 Build Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: 4*120 Build Thread Page: <<   < prev  23 24 25 26 27 28 29 30 [31] 32   next >   >>
Login
RE: 4*120 Build Thread - 7/18/2012 2:27 PM  1 votes
acdii
Score: 155
Last Login: 5/18/2013
Status: offline
  I switched the prop on the DLE20 to an APC 16x6, and that woke the plane up. It flew much better and has some power now.  Lost the left wheel pant though, saw it flutter off.     Happy to say though, the second flight was much better than the first, I didn't hit anything on take off.  Learned to use full rudder rate on take off, thats why I had problems the first few attempts to take off, I was over correcting because it took more rudder on the radio than what i was getting on the plane, so when it didn't react as expected I gave more and then it over corrected.  On Full rate though a touch of rudder gave the expected results, so I was able to take off nice and straight.   Still working on the landing though, after the wheel pant came off, I brought it right in since I didn't know what came off, and I didnt get it lined up right, and brought it in on an angle, so correcting the direction and trying to flare and watch the speed and not hit anything resulted in another bounce and prop strike.
It was also against my good direction, right to left, so overall, I didn't do too bad.  When I come in from the right, it is much further away from me, than from the left, so judging distance is more difficult. There is also an A26 wreck to one side that I need to avoid, and corn on the other.  It is a challenging field to fly from.
But I like the 4*!  Its a good second step up plane from a trainer, unlike the Eflite T-34 that I have. That one is difficult to fly well. Very sensitive on the controls, even with the droops.  It does fly better now with the glow engine on it, it weighs a half pound more, and doesn't float as much as it did, which made landings a pain.  It's hard to land a plane that doesn't want to land.  The 4* floats down nicely too. When I retrieved the plane I noticed that most of my nose weight had fallen off, only 1/4 ounce remained of 2 ounces, and I saw no signs of them on the runway where I landed, so they much have come off in flight, but didn't notice any tail heavy tendencies.  Going to rebalance and glue the weights on this time.
_____________________________
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
(in reply to lamarkeiko)
       Post #: 751
RE: 4*120 Build Thread - 10/18/2012 7:56 PM
Super08
Score: 135
Last Login: 5/17/2013
Status: offline
I just pick up one of these as well. Power will be a 120AX, I plan of clipping the wings one bay, extending the rudder a bit. Otherwise just keeping it as light as I can. I would like to try and get 10 lbs or less for the final weight.
Quote: Hey, who put that tree there?
Ultra Sport brotherhood #125
Hide Signatures
(in reply to acdii)
       Post #: 752
RE: 4*120 Build Thread - 10/18/2012 8:13 PM
acdii
Score: 155
Status: offline
I need to find my iphone cable so I can transfer the pics. gets annoying having to email each one, then save and resize it.
Hide Signatures
(in reply to Super08)
       Post #: 753
RE: 4*120 Build Thread - 10/19/2012 12:09 AM
Gray Beard
Score: 314
Status: offline
AC, Sure is a lot of red!!!! How many rolls of covering did it take??
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to acdii)
       Post #: 754
RE: 4*120 Build Thread - 10/19/2012 2:02 AM
acdii
Score: 155
Status: offline
I dont know how many rolls on the ARF, but Sig sent me 4 rolls to cover the kit.
Hide Signatures
(in reply to Gray Beard)
       Post #: 755
RE: 4*120 Build Thread - 10/20/2012 1:44 AM
Super08
Score: 135
Status: offline
quote:
ORIGINAL: Super08
Well the plan changed today. I am going to let my friend use the 120 in a Super Sportster rebuild and I ordered a DLE-35RE for this build. I did some searching and it should fit inside the cheek cowls without any cutting required. I just need to make the firewall heavier and move it back some. I still plan on cutting out one bay on each wing and I may cut the dihedral in half.
Hide Signatures
       Post #: 756
RE: 4*120 Build Thread - 12/20/2012 10:58 PM  1 votes
Brian Smith
Score: 120
Last Login: 4/14/2013
Status: offline
So how is the DLE 35RA doing in a 4 Star 120? I put a G38 in my first one and am just starting on another and I have a G38 on ignition that I plan to use. Hope more 4* 120 talk shows up. Brian
quote:
ORIGINAL: Super08
quote:
ORIGINAL: Super08
Brian P. Smith Bismith2@hotmail.com
AMA 1044 IMAA 21141 W4BPS <><
Hide Signatures
       Post #: 757
RE: 4*120 Build Thread - 12/20/2012 11:34 PM
brockettman
Score: 105
Last Login: 5/19/2013
Status: offline
Hi guys!
I finally finished mine up, I did not get to fly her before the winter weather set in
She weighs in at 12 pounds powered by a Syssa 180HP (30cc).
Here are a few pictures...
Build well!
Ben
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Club SAITO Member #565
Hide Signatures
(in reply to Brian Smith)
       Post #: 758
RE: 4*120 Build Thread - 12/20/2012 11:49 PM
Brian Smith
Score: 120
Status: offline
Thanks Ben
Pretty slick. I like that... Brian
quote:
ORIGINAL: brockettman
Hi guys!
Build well!
Ben
Hide Signatures
(in reply to brockettman)
       Post #: 759
RE: 4*120 Build Thread - 12/21/2012 12:40 AM
Super08
Score: 135
Status: offline
quote:
ORIGINAL: Brian Smith
quote:
ORIGINAL: Super08
quote:
ORIGINAL: Super08
I'll find out next spring. Right now there is 4 feet of snow on the ground and it is running around 0F.
Hide Signatures
       Post #: 760
RE: 4*120 Build Thread - 12/25/2012 3:27 AM  1 votes
Red_Jeepster
Score: 105
Status: offline
I just found this thread and thought I would share a couple of pics of the 4 * 120 I built for a friend back 10 years ago. Saito 200 V-twin up front!!!
Click for fullsize
Click for fullsize
Click for fullsize
Some Preachers play Golf, I would rather FLY RC!
Ultra Sport Brotherhood #74
Hide Signatures
       Post #: 761
RE: 4*120 Build Thread - 12/25/2012 6:35 PM
acdii
Score: 155
Status: offline
Well that's different!   I should get some pics of mine, its nearly completed, have everything except the elevator and ailerons covered.
Hide Signatures
(in reply to Red_Jeepster)
       Post #: 762
RE: 4*120 Build Thread - 1/3/2013 3:55 PM
Brian Smith
Score: 120
Status: offline
Pictures?? Thanks Mine is slowly coming along. Brian
quote:
ORIGINAL: acdii
Hide Signatures
(in reply to acdii)
       Post #: 763
RE: 4*120 Build Thread - 1/4/2013 7:43 PM
flygilmore
Score: 128
Last Login: 5/16/2013
Status: offline
So, is this kit still offered by Sig? I saw it on their site last time I looked but didn't know if the pics were current and I have not tried asking anyone yet. Thanks.
I didn''''t choose Mojo, Mojo chose me PRO BRO #1963
Hide Signatures
       Post #: 764
RE: 4*120 Build Thread - 1/4/2013 7:51 PM
Brian Smith
Score: 120
Status: offline
It is still on Sig's web site.. Brian
http://www.sigmfg.com/cgi-bin/dpsmart.exe/MainMenuFV5.html?E+Sig
quote:
ORIGINAL: flygilmore
Hide Signatures
(in reply to flygilmore)
       Post #: 765
RE: 4*120 Build Thread - 1/5/2013 1:06 AM
acdii
Score: 155
Status: offline
Yes it is, I am building one that I received from them a few months ago, and the kit is excellent.   If you can still get them, the Aerokote rolls are pretty good. They are wider than Mono and Ultra, and I covered the plane with 3 rolls.
Hide Signatures
       Post #: 766
RE: 4*120 Build Thread - 1/5/2013 8:42 PM
flygilmore
Score: 128
Status: offline
So...I am thinking a G20ei would do ok on this plane if kept light.....what do you think? I know that this plane was meant to be in the 10-11lb. range. I have often thought about getting one and for some reason want 1 real bad here lately. I would have to have wheel pants as they make a world of difference on this plane and a little bit taller landing gear.
Hide Signatures
(in reply to acdii)
       Post #: 767
RE: 4*120 Build Thread - 1/5/2013 8:56 PM
acdii
Score: 155
Status: offline
Mine is coming in around 9 pounds with a DLE20. the landing gear is the same height with or without pants, its predrilled for them.
Hide Signatures
       Post #: 768
RE: 4*120 Build Thread - 1/5/2013 10:18 PM
w8ye
Score: 318
Status: offline
The 4^120 should be fine with the 20cc engines as I've seen them fly OK with a ST90
You may need some nose weight?
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to acdii)
       Post #: 769
RE: 4*120 Build Thread - 1/5/2013 11:15 PM
Brian Smith
Score: 120
Status: offline
+1.. I agree. I have a friend that flys one with a really old G23 and it flys great as far as I'm concerned. It won't hover, but he nor I ever cared about that. Brian
quote:
ORIGINAL: w8ye
Hide Signatures
(in reply to w8ye)
       Post #: 770
RE: 4*120 Build Thread - 1/6/2013 1:19 AM
acdii
Score: 155
Status: offline
This is my second 4*120, the first was an ARF and I flew it with the DLE and it flew great. Stupid wing wasnt glued well and snapped off in flight.
Hide Signatures
       Post #: 771
RE: 4*120 Build Thread - 1/6/2013 1:58 AM  1 votes
flygilmore
Score: 128
Status: offline
I would bend my new landing gear as I've always thought the ones supplied in the kit sit way to low.
The wheel pants could then be fitted to the new gear with no problems.
Hide Signatures
(in reply to acdii)
       Post #: 772
RE: 4*120 Build Thread - 1/6/2013 3:24 AM
acdii
Score: 155
Status: offline
Flew it with a 17" prop and had no clearance problems.  I polished and clear coated mine. Should look pretty sharp.
Hide Signatures
       Post #: 773
RE: 4*120 Build Thread - 1/21/2013 2:56 AM
acdii
Score: 155
Status: offline
Finally took some pics.
Hide Signatures
(in reply to acdii)
       Post #: 774
RE: 4*120 Build Thread - 1/21/2013 4:27 AM
Super08
Score: 135
Status: offline
Very nice, I love that blue!
Hide Signatures
(in reply to acdii)
       Post #: 775
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.375RCU1
