JRexA
Joined: 10/26/2004 From: Nuuk, GREENLAND Status: offline
Since you changed your mind, then you lost the oppertunity to get the only 3 channel radio on the market, that was getting a FREE upgrade to 4 channels Only thing needed is a software/firmware upgrade. They also changed it from std. DSS to Frequenzy Hopping DSS, in order to legally use a higher output power on the system, which insures greater range and even less sensitivity to interferrence. You also get the Telemetrics included in the Radio, which is an expensive add-on on the Spektrum systems. Only "problem" for a Danish user of the Nomad Sensor system is that the CE aproval wasn't totally ready, the last time I checked. You need a CE approved system, to use a 2.4Ghz system for racing under DABU rules. I don't know if the Spektrum DX3 is CE Marked either. Whatch out for the http://www.nomadio.net Black Friday announcement
_____________________________
Jesper Rex, Nuuk, Greenland - FG Leopard Race - 29cc Race Ported - Sensor'ized and Elcon'ized
