kx250ryder
AZ, USA Status: offline
The best analogy I can think of to describe porting, is that you are trying to "build" a river. If you look at the way water flows in a river you can see the similarities. Assume that you are trying to make a river that flows as fast as you possibly can. You want to eliminate all surface imperfections from your river bed (polishing), this is like the rocks sticking up in the river, which make little eddys, and make the current more turbulent, and slower. You can't make the river too wide, or the water will slow to a stop, but on the other side of that, you can't make it too narrow, or you will restrict the ammount of water that can pass (ignoring the fact that rivers overflow). Also, you must ensure that you do not have any sudden changes in direction, which restrict water flow. Its all a balancing act to make sure that you get a maximum volume of air per piston stroke. So basically, unless you can control nature and you wear sandals often, stay away from engine porting. Save that for the guys who have motors named after them.
_____________________________
". . . the same thing we do every night Pinky, try and take over the world." -- Brain
