RE: Kyosho Blizzards
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> RE: Kyosho Blizzards
Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
RE: Kyosho Blizzards - 12/15/2007 6:51:35 AM
The_Stuff
Status: offline
so it didn't run like a conventional nitro motor? it had an oil level and such?
_____________________________
RC''s are like pringles... you can''t have just one!
(in reply to shenlonco)
       Post #: 76
RE: Kyosho Blizzards - 12/15/2007 12:37:11 PM
shenlonco
Status: online
No the nitro motor thay give you is just crap.
Shenlonco
(in reply to The_Stuff)
       Post #: 77
RE: Kyosho Blizzards - 12/15/2007 5:14:25 PM
The_Stuff
Status: offline
wow. bad piston seal then or something.
anyhow here is a pic and action vid i pulled out of my RC vault. stuff is NOT mine!!
< Message edited by The_Stuff -- 12/15/2007 5:16:14 PM >
       Post #: 78
RE: Kyosho Blizzards - 7/10/2008 1:34:00 AM
RC_on_ice
Status: offline
what else do you need to buy to complete the blizzard some sights say there rtr but I know that's not true
(in reply to icecreamslick)
       Post #: 79
RE: Kyosho Blizzards - 7/10/2008 2:17:14 AM
shenlonco
Status: online
all blizzards are kits you need to put them together there is a electric version and a nitro version ...I had both i did not like the nitro version because they used a cheap motor with out ball bearings and nitro oil came out off the bushings and made a mess inside the chassis all the time...so i stuck with my electric one...
see them at kyoshoamerica.com
Shenlonco
(in reply to RC_on_ice)
       Post #: 80
RE: Kyosho Blizzards - 7/10/2008 4:48:11 AM
ksoc
Status: offline
The minimum you need to complete the electric Blizzard is a Radio (Tx, Rx & two servos) and a standard battery pack. Paint for the body would be nice. The "stock" speed control is mechanical, so it could use and upgrade. If you plan to run it in the snow, some water proofing might be called for.
I finished the electric version. Waiting for the winter to try it out on the snow.
Kevin O''C <S.C.A.T> www.socalareatankers.com • Tamiya-Sherman/Tiger/Pershing/Kubelwagen • HL-Tiger, Panzer III
       Post #: 81
RE: Kyosho Blizzards - 7/10/2008 8:00:35 AM
brel
Status: offline
I have the electric version and am taking it on holiday with me tomorrow and plan to run it on the beach near the site that I am staying at in Cornwall, I will post some pictures and video of it on the and hopefully kicking up some rooster tails as it turns on the loose dry sand above the high water mark.
I changed the mechanical speed controller for an esc and put in a Mtronics viper RV max, also upgraded the bushes to bearing races and made some brake pads out of gasket material to help steer the blizzard properly and to stop the brakes grabbing as it turns, I recommend the brake up grade because it smooths out the turns better than metal on metal brakes
< Message edited by brel -- 7/10/2008 10:07:49 AM >
(in reply to ksoc)
       Post #: 82
RE: Kyosho Blizzards - 7/10/2008 2:53:51 PM
shenlonco
Status: online
brel your right about the brakes they suck on the electric version for some reason they did not use the gasket like on the nitro version and the nitro version steers much smoother because of this! I have to upgrade mine with the brake gaskets...just don't feel like ripping it all apart!
Shenlonco
(in reply to brel)
       Post #: 83
RE: Kyosho Blizzards - 7/10/2008 3:43:55 PM
nomobux
Status: offline
Mine .. Metal Flake Orange, brake pad mod, full bearings, lites, 100K Diff oil, Sidewinder/4600 Brushless, water proof box, Spektrum, side snow guards, 6 cell 4200 nimh ( 7 cell 5000 coming ) Recently added the top lighted emergency light bar also.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by nomobux -- 7/10/2008 3:52:27 PM >
" I GOTTS NOMOBUX "
       Post #: 84
RE: Kyosho Blizzards - 7/10/2008 3:50:15 PM
nomobux
Status: offline
Couple more
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
" I GOTTS NOMOBUX "
(in reply to nomobux)
       Post #: 85
RE: Kyosho Blizzards - 7/10/2008 7:15:11 PM
shenlonco
Status: online
NICE that must fly brushless!! bet you go through a lot of chains!!
I have lights up front and rear on mine and a red and blue blinking LED that goes on the top by magnets...
Here is a pic of my 2 blizzards...red gas one i sold...
Shenlonco
       Post #: 86
RE: Kyosho Blizzards - 7/10/2008 8:48:22 PM
nomobux
Status: offline
Nice looking. No, no probs on chains so far, but I have only driven on snow, thus far.
" I GOTTS NOMOBUX "
       Post #: 87
RE: Kyosho Blizzards - 7/10/2008 11:40:02 PM
shenlonco
Status: online
Hey how did you make the brake pads? have any extras you want to sell?
What did you use to glue them to the metal ones?
Shenlonco
       Post #: 88
RE: Kyosho Blizzards - 7/11/2008 12:21:51 AM
nomobux
Status: offline
quote:
ORIGINAL: shenlonco
Just go to a good auto supply and get some quality gasket material approx 1/16th or so thick. CA to your calipers and trim. You will need longer bolts to compensate for the pads. I CA'd all 4 to the material and then trimmed. Just remember to trim the holes on the calipers well. One is elongated. Make sure they move freely
< Message edited by nomobux -- 7/11/2008 12:23:28 AM >
" I GOTTS NOMOBUX "
