futura
SC, USA Status: offline
I'll post the results when it arrives. I may not use all the elements in the end depending on any weight issues that may arrise from the whole kit adding 45 grams. I don't think it will be to big an issue though. The ad mentions "low profile" though I can't see for sure from the pictures. If the kits lowers the Blade CP any, the stock tail will be a problem because its already very close to the ground. I have not done the GWS DD tail mod yet but this could be the right oppertunity. the smaller tail blade will fit the bill. this is the DD upgrade I'm considering GWS Direct Drive Tail Rotor and fittings GWS Tail Bracket GWS EDP50H Motor GWS Heat Sink Spare GWS EP4530 Rotor blade. We will see I guess...
