capngriz
GA, USA Status: offline
OK Big Al, here is my setup: 1 5955 per ail 1 5955 rudder Carbon Spinner - saved 3-4 oz Carbon wing tube - saved 8-9oz Carbon gear - saved 11-12 oz Carbon tail wheel Std Muffs I don't believe (for now) in those light engines and love my DA. I've done more than you've listed and come in at : yes, 28 lbs 2 oz It's a good thing it still flies very light. I think you are wasting your time trying to convence everyone that it will weight less. It DOES fly really well at 28 lbs with all the upgrades. You should come and see. I'm about an hour from you. quote:
ORIGINAL: al With the DA 100 your weight should fall within the 25 to 27 pound range depending on hardware, servos, batteries, exhaust system. 25lb and below You will need to consider one of the light 100 twins or a single cyclinder engine. This is where you would pick up the most weight savings. I like titanium pushrods but if your looking to save weight use carbon fiber, tail wheel assemblies vary greatly from pratcially nothing to over a pound, Main landing gear wheels and hardware. Wheel pants mounts, Control horns all are different weights. We supply a .065 aluminum wall wing and tail tube. I don't do it for weight savings but for strength. There is an option to replace that with carbon fiber for additional savings. These would be some of the areas to consider if you really need to cut down on weight. Here is another thing to consider. sometimes the lighter it is, it can have an adverse effect on the way it performs. Now you have to consider inertia in manuevers, (snaps) wind effect, stall speed and effect that will have on total performance. we all believe that the lighter the better in planes, engines and servos. but consider something has to be sacrificed when making it lighter. On an engine do we leave out a bearing or lighten a crank to paper thin and hope it won't flex or break, Airplanes do we leave out a former or use lighter material such as balsa instead of spruce. maybe it won't twist when doing a snap or roll. or maybe when we pick it up or fly it, it breaks a stringer. Its all a compromise. Sorry to be so winded but those would be areas on any plane to consider when trying to make it as light as possible. Al JTEC/RADIOWAVE
< Message edited by capngriz -- 12/6/2005 6:06:10 AM >
