RE: Official HPI Hellfire Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> RE: Official HPI Hellfire Thread
Page: <<   < prev  76 77 78 [79] 80 81 82 83 84 85   next >   >>
Login
RE: Official HPI Hellfire Thread - 2/12/2010 2:56 AM
RPaulG87
Score: 100
Last Login: 4/20/2010
Status: offline
Got the stainless steel Hellfire screw kit, the difference is night and day, it's like comparing a old ford to a new Rolls Royce, way more threads, extremely strong threads and heads, and they just look great on the truck. I've started taking off and replacing, a few stock ones on the lower chassis are stripped so I may or not replace those, no need for the hassle if I don't need to access that part, but these new screws I am most defiantly not expecting to strip, A+ quality.
Hide Signatures
(in reply to stussman)
       Post #: 1951
RE: Official HPI Hellfire Thread - 2/12/2010 3:00 AM
K-man 15
Score: 100
Last Login: 1/14/2013
Status: offline
the low speed, mid range, and idle adjustment should be set flush with the carberator body and the high speed needle should be set flush with the groove that is on the gold stem that the high speed needle is on
Hide Signatures
       Post #: 1952
RE: Official HPI Hellfire Thread - 2/12/2010 5:34 AM
KeithjV
Score: 125
Last Login: 4/10/2012
Status: offline
Paul which screw set did you get?
Hide Signatures
(in reply to K-man 15)
       Post #: 1953
RE: Official HPI Hellfire Thread - 2/12/2010 6:53 AM
RPaulG87
Score: 100
Status: offline
I bought the RC Screwz Hellfire RTR kit, I noticed a few screws missing..maybe I misplaced them, I unno, I just sobered up and noticed a few are missing...maybe I put them somewhere. The Grabit bit helped me remove another 3 stripped screws, but one I just can't get out, I'll have to dremel it out I guess. I replaced the majority of the bottom screws, can't do the top until my shock towers and what not come in, but here's a sneak peak.
Hide Signatures
(in reply to KeithjV)
       Post #: 1954
RE: Official HPI Hellfire Thread - 2/12/2010 5:38 PM
sleeper341
Score: 100
Last Login: 3/23/2012
Status: offline
quote:
ORIGINAL: KeithjV
You could also have an air leak somewhere. Check the fuel line for cracks and check the carb to make sure its tight
Is there any easy way to check for air leaks? I have inspected the fuel line and as it is all new, there do not seem to be any probs. The carb appears tight too. I'll richen it massively and see what happens to the temp.
Thanks for all the suggestions guys.
Oh, as a long shot, there is sometimes a guy on ebay who sells bulk lots of hellfire parts but he is adamant that he will not ship to the UK. As the hellfire is discontinued, parts here are few and far between. It is cheaper for me to by parts from US sellers and get them shipped here. If this guy happens to list any more bulk lots, would anyone in the US on here accept delivery for me and then reship to the UK (obviously I'd pay for the shipping)?
Hide Signatures
       Post #: 1955
RE: Official HPI Hellfire Thread - 2/12/2010 10:19 PM
RPaulG87
Score: 100
Status: offline
I thought you could still order from HPI? Even with thier discontinued models they still make parts for them for a couple years after they are discontinued.
Hide Signatures
(in reply to sleeper341)
       Post #: 1956
RE: Official HPI Hellfire Thread - 2/12/2010 11:49 PM
stussman
Score: 105
Last Login: 5/25/2012
Status: offline
quote:
ORIGINAL: sleeper341
quote:
ORIGINAL: KeithjV
[/quotE
I had same issue few years back. Couldnt get parts (and you need them for the RTR HF, lots of them!)in Australia.
I ended up getting a used HF off fleabay and use it for all my spare parts needs. Its so easy to have all the parts on hand.
Since then ive puchased the SS version off ebay and it is soooo much better quality and stronger than the RTR. I have a mountain of parts to maintain mine but the SS doesnt break much.
Try and but SS parts if you can.
_____________________________
Always OFF TAP
Finally sold my old hellfire
Hide Signatures
       Post #: 1957
RE: Official HPI Hellfire Thread - 2/13/2010 2:05 AM
sleeper341
Score: 100
Status: offline
quote:
ORIGINAL: RPaulG87
The HPI Europe website in the UK has next to no parts anymore. In the UK HPI uses a distributor called Mirage Racing to supply everything.(they run the HPI Europe website). So I guess the distributor don't want to buy in parts for a car that's dicontinued.
As for buying a secondhand SS or RTR for parts off ebay, they hardly ever come up and when they do they're still about US $200+   but I keep looking there becuase I might get a bargin one oneday
Hide Signatures
(in reply to RPaulG87)
       Post #: 1958
RE: Official HPI Hellfire Thread - 2/13/2010 3:31 AM
nitroexpress
Score: 150
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: RPaulG87
On EBay, HPI Hellfire gets 880 hits. There are a number of online hobby stores that carry parts. So what's the problem again?
http://stores.ebay.com/HopMeUp__hellfire_W0QQ_fsubZ6117887QQ_sacatZHopMeUpQ5fQ5fW0Q51Q51Q5ffsubQ5A6117887Q51Q51Q5fpgnQ5A3Q51Q51Q5fscQ5A1Q51Q51Q5fsopQ5A3QQ_scZ1QQ_sidZ179995618QQ_sopZ3QQ_trksidZp4634Q2ec0Q2em14?_pgn=2
http://www.rcplanet.com/SearchResults.asp?Search=hpi+hellfire
http://www.amainhobbies.com/advanced_search_result.php?keywords=hpi%2520hellfire&sort=pop&filter_mfr=16&filter_cat=240
Hide Signatures
       Post #: 1959
RE: Official HPI Hellfire Thread - 2/13/2010 4:35 AM
3130pembroke
Score: 100
Last Login: 6/24/2010
Status: offline
those 4.6HO always run hot if you want to get any real power out of it- if its smokin and running hot you probably have weak compression
what you get for a $100 motor
I have another tip for steering issues - epoxy the bellcrank to the servo saver post- that hex head does not hold tight in the plastic :-P
Hide Signatures
(in reply to nitroexpress)
       Post #: 1960
RE: Official HPI Hellfire Thread - 2/13/2010 7:41 AM
K-man 15
Score: 100
Status: offline
When I have my Hellfire sitting up on a stand or something that keeps the wheels off the ground the wheels can turn left and right quite a bit with out the servo horn even moving, and I dont think it is supposed to do that or am I wrong?
Hide Signatures
(in reply to 3130pembroke)
       Post #: 1961
RE: Official HPI Hellfire Thread - 2/13/2010 7:51 AM
KeithjV
Score: 125
Status: offline
Is the there enough tension on the spring on the servo saver?
Does the servo horn move too?
Hide Signatures
       Post #: 1962
RE: Official HPI Hellfire Thread - 2/13/2010 7:56 AM
K-man 15
Score: 100
Status: offline
No the servo horn does not move when it does this because it pretty much just moves freely when i use my hand to turn the tires left and right.
How do I add more tension to the spring on the servo saver?
Hide Signatures
       Post #: 1963
RE: Official HPI Hellfire Thread - 2/13/2010 8:01 AM
KeithjV
Score: 125
Status: offline
The bottom plate screws up to tighten the spring.
When you move the wheels back and forth what else is moving? Something must be loose
Hide Signatures
       Post #: 1964
RE: Official HPI Hellfire Thread - 2/13/2010 8:34 AM
K-man 15
Score: 100
Status: offline
Its just the steering plate and the wheels that turn and then it goes to the servo saver and I checked the servo saver and there is little to no tension at all on the spring so I screwed that collar and it tightened and it is a little better but it is now to tight to tighten by hand so what can I use to tighten it more?
Hide Signatures
       Post #: 1965
RE: Official HPI Hellfire Thread - 2/13/2010 8:38 AM
KeithjV
Score: 125
Status: offline
needle nose pliers should work. You dont want to over tighten it to the point the spring can flex though.
Hide Signatures
       Post #: 1966
RE: Official HPI Hellfire Thread - 2/13/2010 8:40 AM
K-man 15
Score: 100
Status: offline
OK Thanks for your help. I will take it to the bench and see what I can get done.
Hide Signatures
       Post #: 1967
RE: Official HPI Hellfire Thread - 2/13/2010 8:42 AM
KeithjV
Score: 125
Status: offline
No problem. Let us know how you make out.
Hide Signatures
       Post #: 1968
RE: Official HPI Hellfire Thread - 2/13/2010 9:01 PM
K-man 15
Score: 100
Status: offline
quote:
ORIGINAL: KeithjV
Well that problem is fixed! Thanks for all of your help KeithjV, it is greatly appreciated.
Hide Signatures
       Post #: 1969
RE: Official HPI Hellfire Thread - 2/13/2010 10:27 PM
KeithjV
Score: 125
Status: offline
Cool, thats all it was? Glad we got ya going so easily.
Hide Signatures
       Post #: 1970
RE: Official HPI Hellfire Thread - 2/14/2010 6:08 AM
RPaulG87
Score: 100
Status: offline
Finally got my Integy HD Shock towers in, I really can't see why people hate Integy so much, they seem like such good parts...even if they were "lacking" in the aluminum they use, their parts have so much MORE that there is no way stock is stronger. I took a pic of the stock aluminum shock tower right next to the Integy HD one, BIG difference.
Hide Signatures
       Post #: 1971
RE: Official HPI Hellfire Thread - 2/14/2010 7:26 AM
nitroexpress
Score: 150
Status: offline
Are you comparing a RTR tower to the Integy? Cuz there is no way that Integy is as good as a SS part. Trust the majority of people, Integy is crappola.
Hide Signatures
       Post #: 1972
RE: Official HPI Hellfire Thread - 2/14/2010 7:44 AM
RPaulG87
Score: 100
Status: offline
You mean am I compareing a 15$ shock tower to a 45+$ shock tower? No I'm comparing it to the stock one, which I posted a photo of :P, Integy parts sure do look nice though, and they are def beefy.
Hide Signatures
       Post #: 1973
RE: Official HPI Hellfire Thread - 2/14/2010 8:05 AM
stussman
Score: 105
Status: offline
Yeah the RTR shock towers bend very easily. The SS are quite good quality.
The integy surely must be better than the stock.
Always OFF TAP
Hide Signatures
       Post #: 1974
RE: Official HPI Hellfire Thread - 2/14/2010 8:44 AM
nitroexpress
Score: 150
Status: offline
SS towers are $39 at AMain or
http://cgi.ebay.com/HPI-Hellfire-Billet-Heavy-Duty-Alloy-Shock-Tower_W0QQitemZ370334873697QQcmdZViewItemQQptZRadio_Control_Parts_Accessories?hash=item5639adb861
But some people have to learn the hard way. Integy are not better than the RTR towers.
Hide Signatures
       Post #: 1975
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.000RCU1
