Stud length
Tower Hobbies
Logged in as Guest
  Printable Version
K&B .40 R/C Ball Bearing
Seller:  area51jmitch
Details:   $75.00   |  8/28/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> Stud length
Page: [1]
Login
Stud length - 11/24/2005 8:32:05 PM
MJD
Status: offline
Now there's a subject line that could raise an eyebrow..
Hi Bob,
I was fiddling with my pylon prop assortment just received from APC, and when fitting one to my SJ50 last night to admire it I was concerned about the very small amount of prop stud remaining. The stud on mine measures 0.70" long, and the hubs on these 8.8" props measure around 0.56" - 0.57", leaving barely over 1/8" of thread engagement. That seems marginal to say the least, esp. with aluminum threads.
What's the scoop?
MJD
       Post #: 1
RE: Stud length - 11/29/2005 3:57:45 PM
bob27s
Status: offline
Hey...
Thanks for writing
The threaded stud can be adjusted a bit. Dub also has 2 sizes available if needed.
The normal installation on the prop stud, is to thread it into the crankshaft all the way until it stops, then back it out about 2 turns. You do not want it to bottom out in the crankshaft.
To make it longer, you can back the stud out a bit more. Take the stud out, thread it back in a mimimum of 8 turns. This gives you about 3/16" of adjustment.
Bob
_____________________________
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to MJD)
       Post #: 2
RE: Stud length - 12/13/2005 11:11:52 PM
MJD
Status: offline
Ah yes.. I never even tried, but the stub loosened up with a gentle tweak, and indeed I can get it in 8 turns or more and have enough engagement for the pylon prop hubs. That was simple..
Ya loin sometin' new every day..
Thanks!
MJD
(in reply to bob27s)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.234RCU1
