algutkin -> RE: Hobby Lobby Sr. Telemaster ARF (12/27/2006 10:08:35 PM)
Hi Calixto, I can't tell you about the nitro motors, however, the 9X6 props need to turn 9,000 RPM in order to get his baby to fly nice. Some others are using 10 inch props, however, I found the 9X6 to be a good combination with electric. Yes, I know you are considering nitro, but, the prop size is limited by the distance from the fuse, so 10.5 is max, and they need to turn 8,000 to 9,000 RPM. The plane flies good if you check the wing incidence, some planes were manufactured with negative wing incidence and were hard to fly. The CG point is 80MM back of the leading edge, disregard the what the manual says. The Transall looks good, but, lands on the fast side, it does not float. Hope I helped. Al
