randall1959
MO, USA Status: offline
My glow AP plane is nearly overpowered so that's mainly how I get away with it. I also stretched the wing out on both ends for more lift. Drag is not a critical issue on a big floater plane and will also help it fly more slowly in some cases. My plane weighs 9 lb fully loaded, but with a 72" wing it lands at little more than walking speed, even in light breezes. I've dead sticked it a couple of times to see how it glides and even being as heavy as it was, it still glided for quite a long time and came in nice and slow. My glow ap plane actually flies a lot like it did when it was a simple trainer. The ground handling was a bit tricky until I figured out that my configuration needs "up" thrust instead of down. If Skycam were to elevate his motor, on a pusher it would also need some "up" thrust so as to not want to push the nose over under power. Right now I'm happy with my glow plane so now my attention is focused on building a couple of good electric ap planes. Much more people friendly and easier to transport. But for shots out in the country it will most definately be the slimer. Say what ya want, but a slimer stays in the air longer, less power issues, and will allow you much more in lifting power.
< Message edited by randall1959 -- 11/28/2005 2:37:31 AM >
_____________________________
I meant to do that.........
