W4UAV
FL, USA Status: offline
Put it on the CG, if you develop fuel flow problems, install a header tank near the firewall, I dont think youll have problems, I just did a test on my new twin boom and had about 12" of fuel line to the engine, it took a little priming but once it got going it was fine. You'll have plenty of pressure from the Irvine 53. Yes initially youre going to think the plane will never be balanced with the engine and tail booms behind the CG, but as you add your receiver pack to the nose, (I have a couple lying around, different capacities, different weights) and youll be putting in the camera gear to just forward of the CG, calculate all the weight you will be carrying around all the time, the camera, transmitter and its battery and put those in there and youll see itll balance out, youll find this way if you have to balance it one way or the other itll only take a small amount to balance it on the CG. When I did the first flight of Grey Ghost I put two huge 2000 mah packs in the front because I hadnt put in the camera gear yet, when I did add it, I just removed one of the packs and it was fine. Mike
< Message edited by W4UAV -- 11/27/2005 3:47:29 PM >
_____________________________
Mike Robinett W4UAV
