RE: GEE BEE R3 RACER??WOW!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Scale Racing >> RE: GEE BEE R3 RACER??WOW!!! Page: <<   < prev  1 2 3 4 5 6 7 [8] 9 10   next >   >>
Login
RE: GEE BEE R3 RACER??WOW!!! - 10/8/2009 10:23 PM
mfuess
Score: 100
Last Login: 11/1/2010
Status: offline
quote:
ORIGINAL: Glacier Girl
Well I wrapped up mine tonight. ''E'' powered!!! 1000+ watts spinning a 14 x 13 x 3 APC.
Couple of the things I did differently.
Added a simple cockpit and pilot, couldn't stand the open bare frame work showing.
Built the rudder and elevator controls inside so no linkages hanging out to spoil the view.
Added a pair of vents to exhaust the airflow, and blocked off most of the fire wall area to allow only airflow over the motor/esc/packs.
Cowl is magnetic latched, single screw on top locks the front of the main hatch, cowl, and fire wall together. Remove the screww, the cowl pops forward and makes the hatch easy to remove and install.
Added some holes at the rear of the hatch mount area to let air escape back into the fuselage and out the vent holes, so hopefully no popping off of the hatch.
Rebuilt the aileron servo mounts, and built covers, didn't like the whole top of the servo sticking out, now its just the arm. If I had thought ahead before I glued in the ailerons, I would have probably gone with torque rods so there was no linkages hanging out at all for the ailerons.
And finally replaced all the tires with rubber versions.
If the flying wires don't hold up, I'm going to order a set for the Hangar9 Camel for it. Hardware is much better quality, and comes with turnbuckles for adjusting the tension, so no clevises to deal with.
Excellent!!!!
Hide Signatures
(in reply to Glacier Girl)
       Post #: 176
RE: GEE BEE R3 RACER??WOW!!! - 10/18/2009 5:13 PM
mfuess
Score: 100
Status: offline
I ended up putting a Zenoah G26 in my R3. The OS 95AX just didn't have much go-power. While the aircraft does weigh more, it still flies well.
Hide Signatures
(in reply to mfuess)
       Post #: 177
RE: GEE BEE R3 RACER??WOW!!! - 10/18/2009 5:28 PM
Wingspam
Score: 100
Last Login: 6/5/2013
Status: offline
This is from the same man who put a DA 50 into a Great Planes RV-4 60-90 size plane.... ROLFMAO... Good Job..
_____________________________
Wingspam
Hide Signatures
       Post #: 178
RE: GEE BEE R3 RACER??WOW!!! - 10/18/2009 6:58 PM
mfuess
Score: 100
Status: offline
quote:
ORIGINAL: Wingspam
That would be me...
After nearly 600 flights with the DA-50 powered RV-4, I sold the airframe to JGraham and Jryan bought the engine. The RV-4 is now G38 powered, and still flies great!
Hide Signatures
(in reply to Wingspam)
       Post #: 179
RE: GEE BEE R3 RACER??WOW!!! - 10/18/2009 8:28 PM
jfassino
Score: 100
Last Login: 6/19/2013
Status: offline
quote:
ORIGINAL: Wingspam
Give him a break the DA 85 was not available at the time he chose the DA 50. Plus he is a master at helping us glow guys learn about gas engines and carbs. Thanks MFuess
Jim Fassino
Hide Signatures
       Post #: 180
RE: GEE BEE R3 RACER??WOW!!! - 10/18/2009 11:54 PM
mfuess
Score: 100
Status: offline
I put several flights on the R3 today and it flew great! My Zenoah G26EI flew the airplane quite well. It's no speed monster but it's impressive none the less.
Hide Signatures
(in reply to jfassino)
       Post #: 181
RE: GEE BEE R3 RACER??WOW!!! - 10/19/2009 1:45 AM
Wingspam
Score: 100
Status: offline
Mark knows I was just ribbing him, I loved to watch that Rv fly...
Wingspam
Hide Signatures
       Post #: 182
RE: GEE BEE R3 RACER??WOW!!! - 10/19/2009 2:28 PM
mfuess
Score: 100
Status: offline
You have to be tough-skinned to fly at GSW. The peanut gallery doesn't cut anyone slack...
Hide Signatures
       Post #: 183
RE: GEE BEE R3 RACER??WOW!!! - 10/25/2009 8:58 PM
Glacier Girl
Score: 122
Status: offline
quote:
ORIGINAL: mfuess
What you fly with no pants? Oh my!
Well just gotta cut my own decals, and she's done.
I give all my planes names, this one's "Hee Bee Gee Bees" Just in time for Halloween
Missing Man Formation, Looking heavenward you can''t help but shed a tear,mournful, lonesome, a hole that screams out at you
Hide Signatures
       Post #: 184
RE: GEE BEE R3 RACER??WOW!!! - 10/25/2009 11:54 PM
mfuess
Score: 100
Status: offline
No pants & NO UNDIES....
I have about 8 flights with the Zenoah G26 and I'm very happy with it...
Hide Signatures
       Post #: 185
RE: GEE BEE R3 RACER??WOW!!! - 12/29/2009 6:29 PM
benjaminvessey
Score: 100
Last Login: 5/14/2012
Status: offline
I hope I'm not to late to get a little help. I'm new to this forum thing but since I will be the only one at my field with one of these things, I need some help. My girlfriend bought me the Gee Bee for Christmas and so far it is going together pretty well. need some 4 stroke power recomendations. I'm thinking of an OS 1.20 with a pump and mount it inverted. I've never had a Saito but have thinking about trying one out. I will post some pics this afternoon.
Hide Signatures
       Post #: 186
RE: GEE BEE R3 RACER??WOW!!! - 12/29/2009 8:08 PM
mfuess
Score: 100
Status: offline
quote:
ORIGINAL: benjaminvessey
You won't be happy with a 1.20... I guarantee. You need at least a Saito 1.80 preferably a 2.20.
Hide Signatures
(in reply to benjaminvessey)
       Post #: 187
RE: GEE BEE R3 RACER??WOW!!! - 12/29/2009 9:08 PM
benjaminvessey
Score: 100
Status: offline
How well will a Saito Run upside down without a pump? would I need to install an onboard glow system?
Hide Signatures
       Post #: 188
RE: GEE BEE R3 RACER??WOW!!! - 12/29/2009 9:45 PM
mfuess
Score: 100
Status: offline
It will run GREAT! No on-board glow necessary.
Hide Signatures
       Post #: 189
RE: GEE BEE R3 RACER??WOW!!! - 12/29/2009 10:37 PM
benjaminvessey
Score: 100
Status: offline
This is my first R3. But my second GP R2. I lost the first one after the nylon bolts sheered and the wing departed . I just hope the R3 is as much fun!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 190
RE: GEE BEE R3 RACER??WOW!!! - 1/9/2010 4:37 PM
DennyD
Score: 100
Last Login: 5/5/2013
Status: offline
I wonder if you could help me . I also put a 26 in mine after reading all the threads. I have never seen any mention of the down thrust built into the engine mount. Any comments on this ? Seems excessive.
Denny
Hide Signatures
       Post #: 191
RE: GEE BEE R3 RACER??WOW!!! - 1/10/2010 11:01 PM
DennyD
Score: 100
Status: offline
Follow up to the previous post.
Just wanted top clear this up . On my R3 purchased, about 3 months ago , (Hobby Lobby had a great sale) I found that the firewall had about 3 degrees of down thrust, NO right thrust. Is this the latest revision ? Any comments or help would be appreciated.
Denny
Hide Signatures
(in reply to DennyD)
       Post #: 192
RE: GEE BEE R3 RACER??WOW!!! - 2/13/2010 3:17 AM
roaddog2
Score: 120
Last Login: 6/10/2012
Status: offline
I've got a video... somewhere... of someone flyin' one o' these. From th' vid, it appears superb!
RD
Th'' Roaddog
Montross, Va
Hide Signatures
(in reply to jlkonn)
       Post #: 193
RE: GEE BEE R3 RACER??WOW!!! - 4/7/2010 2:24 PM
viper66
Score: 100
Last Login: 9/15/2010
Status: offline
Hi
Hoping someone could help me
I need a rear horizontal elevator for the Gee Bee my 8yr old son tripped over and landed on the right side snapping of the horizontal fin.
cheers
Steve
Hide Signatures
       Post #: 194
RE: GEE BEE R3 RACER??WOW!!! - 9/3/2010 12:10 AM
geebee r1
Score: 100
Last Login: 3/7/2012
Status: offline
starting new projet geebee model D 40 % 3,70m or 146 inches
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to viper66)
       Post #: 195
RE: GEE BEE R3 RACER??WOW!!! - 10/20/2010 1:03 AM
geebeepilot1
Score: 100
Last Login: 9/6/2012
Status: offline
I've been looking for a GEE Bee R3 59 inch ARF for months. Where and when did you get your R3
Hide Signatures
       Post #: 196
RE: GEE BEE R3 RACER??WOW!!! - 10/25/2010 7:53 PM
geebee r1
Score: 100
Status: offline
a french friend of my work in a factory were making stuff with fiberglass
he is flying also and he make the fuselage
Hide Signatures
(in reply to geebeepilot1)
       Post #: 197
RE: GEE BEE R3 RACER??WOW!!! - 11/22/2010 5:48 AM
nexusdc5
Score: 100
Last Login: 12/18/2012
Status: offline
Hello all, Im very new to this forum regarding the Gee Bee R3 59 inch span. I stumbled upon a guy selling one of these beauties on RCU. I did some research on this plane and it was beautiful. So I bought it, the guy is out of Canada and he says he can get more if anyone is interested. I should be getting mine this week. The Quality of this aircraft is amazing. Just wanted to share the good news. Need to find time to start building it along with the 32% CARF Gee Bee Im presently building. Im putting a Moki 250 in it. Absolutely breath taking combination in Sound and Flight. Sounds like the real thing. Anyways.... Cheers and good luck. Let me know if anyone is interested in information regarding possibly getting one of these beauties and ill put you in touch with the gentle man I bought mine from.
Hide Signatures
(in reply to geebee r1)
       Post #: 198
RE: GEE BEE R3 RACER??WOW!!! - 12/11/2010 1:04 AM
kev71h
Score: 100
Last Login: 6/6/2012
Status: offline
subscribe
"If you got it....race it"
Hide Signatures
(in reply to nexusdc5)
       Post #: 199
RE: GEE BEE R3 RACER??WOW!!! - 1/4/2011 7:39 AM
TTRotary
Score: 100
Last Login: 4/30/2013
Status: offline
quote:
ORIGINAL: nexusdc5
Aww man, I don't care if she flies like a buckin bronco. I'd kill for one of these gorgeous planes. Please let us know what your Canadian friend can do. I emailed the French hobby company that carried them, waiting for a response...
Meanwhile, I've got my Cermark Fantasy Racer, but it's not the same. Very nice flyer though.
Hide Signatures
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.000RCU1
