RE: Got my NEW Edge
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: Got my NEW Edge Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: Got my NEW Edge - 11/30/2005 10:46:22 PM
rlmcnii
Status: offline
b.b.
When installing the round, snap-rings that attach the EZ connetors to a servo arm or control horn this works real well:
Drill a 1/16 hole in a piece of wood, place the snap ring over the hole and the arm over the snap-ring, hold the EZ connector atop everything and tap it with a light hammer. Nothing flies anywhere(bt, dt) and all goes together easily.
(in reply to ben beyer)
       Post #: 26
RE: Got my NEW Edge - 11/30/2005 11:45:02 PM
ben beyer
Status: offline
That's a good idea, thanks. I found a snap washer today sitting on the couch. I just looked down and there it was.
_____________________________
Team DOD Member
www.downonthedeck.com
(in reply to rlmcnii)
       Post #: 27
RE: Got my NEW Edge - 12/1/2005 4:39:02 AM
airborneSGT
Status: offline
We must be talking about apples and oranges. I use these connectors for my H-stabs.
Click to see fullsize image.
Click for fullsize
       Post #: 28
RE: Got my NEW Edge - 12/1/2005 4:43:21 AM
airborneSGT
Status: offline
From the same company that makes outdoors equipment as well. Get R done.
(in reply to airborneSGT)
       Post #: 29
RE: Got my NEW Edge - 12/1/2005 7:12:15 AM
ben beyer
Status: offline
The glue had cured on the elevator pushrods so I got those put on. I tried setting up the pull-pull cable, but the cable broke. I think I may have put a bend in it trying to get a small loop. Are my loops too small? Oh, and I was talking about the DuBro connectors that go on the control horns and have a set screw.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Team DOD Member
       Post #: 30
RE: Got my NEW Edge - 12/1/2005 2:49:04 PM
rctom
Status: offline
Our very first hardware kits used those Dubro kwik links, but I learned of two problems very quickly.
The little slide locker is so thin it will straighten out the first time you push on it. Worse, the little pin is just pressed into one side. When you push it out to clear the servo arm it almost always falls out on the floor or in the grass. It's so tiny that it gets lost and there are no spares available.
That's why we use the Sullivan parts.
TF
       Post #: 31
RE: Got my NEW Edge - 12/1/2005 5:18:45 PM
rlmcnii
Status: offline
The EZ connectors to which I was referring are the barrel-shaped or hexagonal brass connectors that attach to servo arms. The wire on the pushrod slides through a hole in the brass fitting and is secured with a set-screw. These connectors make it possible to make very fine mechanical adjustments to the control set-up without opening and closing clevises at the control surface. Once set up I use a drop of Locktite on the set screws.
Are these fitting appropriate for a 28% W.H. Edge????
(in reply to rctom)
       Post #: 32
RE: Got my NEW Edge - 12/1/2005 5:41:21 PM
zzw26n
Status: offline
Use the EZ connectors on chokes, throttle maybe, but other then that, your waiting for an accident to happen
       Post #: 33
RE: Got my NEW Edge - 12/1/2005 8:21:37 PM
ben beyer
Status: offline
The only place I use those are on throttle and now choke. I would never trust one to a control surface on any plane.
Team DOD Member
(in reply to zzw26n)
       Post #: 34
RE: Got my NEW Edge - 12/1/2005 10:47:25 PM
flier
Status: offline
Ben,
Wrap a piece of fuel tubing (split down the side) around the pick up wire for better protection and then secure with a few cable ties.
The insulation could vibrate against the engine mount and be worn through.
Everything else is looking real good.
Click for fullsize
flier
I3D, AMA, IMAC, & IMAA
       Post #: 35
RE: Got my NEW Edge - 12/1/2005 11:02:18 PM
rlmcnii
Status: offline
zzw26n,
I am not questioning your reply. However, have you ever had one of these EZ connectors fail? I have recently re-entered R/C after a thirty year hiatus and a lot is new. I have used these connectors very successfully on a Bruce Tharpe Flyin'King. It is fairly large (79"span), but light (about 10 pounds) and flies in a manner (slowly) that does not heavily load the control surfaces.
I am about to start on my W.H. 28% Edge and did not intend to use these connectors in that airplane....I agree with you!
However, I wonder how unreliable these connectors are.
Anyone out there have anything to ad?? OR, is this a new thread?
       Post #: 36
RE: Got my NEW Edge - 12/1/2005 11:15:38 PM
Josey Wales
Status: offline
quote:
ORIGINAL: ben beyer
I wouldnt even use them for the choke or throttle..I had them come off my throttle on my 60 size glow planes..last week my buddy was flying his 4 star 40 and lost the throttle..loctite and everything..when you move up to these planes you need to step up the hardware a bit
Joe
       Post #: 37
RE: Got my NEW Edge - 12/1/2005 11:33:39 PM
rctom
Status: offline
EZ connectors are not appropriate for a plane this big on the control surfaces.
I use them all the time on throttle and choke, though.
TF
(in reply to Josey Wales)
       Post #: 38
RE: Got my NEW Edge - 12/1/2005 11:38:02 PM
airborneSGT
Status: offline
Yes a few dozen of those brass things later I may switch to the Sullivan ones. Kudos for using those on your Hardware kits. There is a method behind all the hardware included and it makes sense!
The Edge would be a neat electric conversion. A big electric flying buddy of mine is asking about converting a WH.
Ben - the pull-pull wire works great, but I also like to use the kevlar pull pull cable.
(in reply to rctom)
       Post #: 39
