Noob Needs Help!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Painting, Detailing & Bodies >> Noob Needs Help!
Page: [1]
Login
Noob Needs Help! - 11/27/2005 6:25:57 PM
zak33_33
Status: offline
After looking over threads of bodies i decided that my revo needs a new look. I would like a basic body like a ram or a f130 an then to have it blue with white stripes going up the middle. Can you post your hints and tips including paints and stripes. I appriciete any replys,
zach
_____________________________
Revo: OS .18TM Single servo conversion, FOC, wing mod, green up fornt tan in rear (50wt oil) , glow starter, F-150 BOD
       Post #: 1
RE: Noob Needs Help! - 11/28/2005 6:19:31 PM
zak33_33
Status: offline
14 hits and nobody knows anything?
(in reply to zak33_33)
       Post #: 2
RE: Noob Needs Help! - 11/28/2005 8:37:42 PM
TQ Batman
Status: offline
I am a noob too, but you can try using the liquid mask and then draw your design on the outside of the body. Then you can use some type of blade to cut the design out. Try not to be too thin or too thick with the mask. Too thin and it won't come off, too thick and it won't dry.
I used this technique on my LST.
< Message edited by skyodyssey -- 11/28/2005 8:39:41 PM >
Maintenance is overrated!!!
       Post #: 3
RE: Noob Needs Help! - 11/28/2005 9:42:15 PM
PitStops
Status: offline
here are a couple of shells I have done with racing stripes
maybe this will help you a bit
The way I do my racing stripes is super simple. descide on how wide you want your stripes and find masking tape of that width, you can do multiple widths as well. descide where you want them to sit on the shell (i usually will lay the tape down on the outside to get a feel for where I want them to sitoutline them with a sharpie then prep you body by washing it with hot soapy water, scuff the inside of the body with a piece of steele wool or a soft scrubbing pad (scotch brite) wash it again lay in your window masks and tape off your stripes by following inside the lines you marked on the outside of the shell. if you are painting stripes darker then the base color you will have to mask the entire body except for the stripes and paint them first. if you base color is darker just mask off the stripes paint the base color then remove the masking tape and paint the stripes.
Let the paint dry between light even coats of each color and when you are finished with each color before removeing the masking.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by PitStops -- 11/28/2005 9:57:37 PM >
Pitstops Racing Team & Drift Team
Team Magic G4 pro, GS Vision Pro, FT TC4, MBX5
(in reply to TQ Batman)
       Post #: 4
RE: Noob Needs Help! - 11/29/2005 6:23:41 PM
zak33_33
Status: offline
Thats a great help!
zach
(in reply to PitStops)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU1
