diff
Tower Hobbies
Logged in as Guest
  Printable Version
Tamiya Land Cruiser CR-01 Crawler w/ ESC - Kit
Seller:  sheograth
Details:   $300.00   |  11/16/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> diff
Page: [1]
Login
diff - 11/27/2005 7:28:50 PM
ZX1
Status: offline
HI what diff oil do i use on a rough bumpy dusty track also shock oil and must i remove stabiliser bars the track is very harsh and lots of jumps i run a mayhem thanks
       Post #: 1
RE: diff - 11/27/2005 11:14:45 PM
Super_Dave
Status: offline
If the tracks rough that wont be a reason to change diff oil. The consistancy is a reason to change diff oil. Normally if the dirts very loose you want heavier oil to make sure all of the tires are getting more power to pull it through the loose dirt. If the diff oil is light then it just throws the power to the wheel with the least amound of grip.
For shock oil I wouldn't go any lower then 30 weight. Anything between 40 and 30 would be good just make sure the rear doesn't have a heavier weight or the buggy will probably try to nose dive off of jumps. Also go with soft or medium springs. The rest is all in your racing line. Try to find one that will let you get through the section smooth.
(in reply to ZX1)
       Post #: 2
RE: diff - 11/28/2005 12:19:30 AM
SManMTB
Status: offline
Dave, I don't know why you say you get nose dive if you've got lighter oil in the front? Tried 40wt front / 45wt rear on the K3 and it doesn't dive.
Take off the sway bars too. Supposed to work better on a bumpy track.
(in reply to Super_Dave)
       Post #: 3
RE: diff - 11/28/2005 2:13:01 AM
Super_Dave
Status: offline
I've tried it before with my hyper and it nosedived quite a bit. Depends on the buggy too.
(in reply to SManMTB)
       Post #: 4
RE: diff - 11/28/2005 2:50:37 AM
SManMTB
Status: offline
I guess it does.
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU3
