Stock muffler for ST G-2300 ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Stock muffler for ST G-2300 ?
Page: [1]
Login
Stock muffler for ST G-2300 ? - 11/29/2005 8:13 PM
Sturtz
Score: 100
Last Login: 12/22/2012
Status: offline
Does anybody have a stock G2300 muffler they don't need anymore ?
I had another deadstick with my new G-2300 the other day causing some major repairs to be made. When the landing gear sheared it's nylon bolts the stock ST muffler came apart in three pieces. I was surprised to see that it was pressure fitted together.
Because of low funds $ I have JB-Welded it back together using the oven on warm as a curing station. I then saftey wired it .
So far during two tank fulls run in the garage I have had no problems. But I fear the worst if flown like this.
I have a brand new OS 91FX muffler I could use as trade if needed.
Thank you in advance.
On another G-2300 note I discovered a simple fix others may want to try. After putting my engine back on my repaired plane I got the RTV "red " and applied a bead around where the carb flushes up to the intake. This must have cured a tiny air leak because the mid range is way better now and I see no wetness (fuel residue) around the engine anymore.
_____________________________
Kurt
AMA# 794291
Saito Club #121
Hide Signatures
       Post #: 1
RE: Stock muffler for ST G-2300 ? - 11/29/2005 9:41 PM
w8ye
Score: 318
Last Login: 5/21/2013
Status: offline
The old type swing muffler was riveted together.
The new style with the fins has a bolt that goes all the way through it. You will not find a bolt that long but you can use a piece of threaded rod.
Is this the kind you have?
Enjoy,
Jim
< Message edited by w8ye -- 11/29/2005 9:44 PM >
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to Sturtz)
       Post #: 2
RE: Stock muffler for ST G-2300 ? - 11/29/2005 10:36 PM
Sturtz
Score: 100
Status: offline
Hi Jim, always glad to see your posts/comments. Yes, it's the newer one with the long bolt. I still have the bolt from my busted muffler. It didn't get bent or ruined. It simply pulled through the back of the muffler. I replaced the washers with better steel ones and got a lock nut for it instead of the twin nuts. But the rear muffler area was too damaged to reuse the bolt. So I JB-Welded everything.
Kurt
AMA# 794291
Saito Club #121
Hide Signatures
(in reply to w8ye)
       Post #: 3
RE: Stock muffler for ST G-2300 ? - 11/29/2005 11:36 PM
seanychen
Score: 105
Last Login: 2/23/2008
Status: offline
I have the stock muffler, the new kind, never used it. If you want it, PM me.
E_Total = M*G*H + 1/2 M*V^2
When H=0, all of airplane's velocity becomes crash energy!
Hide Signatures
       Post #: 4
RE: Stock muffler for ST G-2300 ? - 11/30/2005 12:06 AM
Cyclic Hardover
Score: 100
Last Login: 5/12/2013
Status: offline
i have one also. i am using a jettstream in place of the stock. i am typing with one hand here. i am a platelet donor for luekemia patients. each station has nice computers with dvd and internet.
Retired Army Aviator - Where the heck have I been?
Hide Signatures
(in reply to seanychen)
       Post #: 5
RE: Stock muffler for ST G-2300 ? - 11/30/2005 12:12 AM
Sturtz
Score: 100
Status: offline
That is so great that you guys will let one go. I have a few stock mufflers around here too that I never used because of after market pipes and Pitts. A few are still in the box new. But no SuperTigre.
"I PM'd you Sean."
< Message edited by Sturtz -- 11/30/2005 4:28 AM >
Kurt
AMA# 794291
Saito Club #121
Hide Signatures
(in reply to Cyclic Hardover)
       Post #: 6
RE: Stock muffler for ST G-2300 ? - 11/30/2005 2:39 AM
w8ye
Score: 318
Status: offline
Kurt,
I got your message and read the post. It's too bad Super Tiger doesn't sell parts for these.
Jim
< Message edited by w8ye -- 11/30/2005 4:56 AM >
Original AMA #31261
Hide Signatures
       Post #: 7
RE: Stock muffler for ST G-2300 ? - 11/30/2005 4:31 AM
Sturtz
Score: 100
Status: offline
It's too far gone to replace parts on. And a new one costs more than a Pitts style muffler.
Don't get me wrong here guys. I'm willing to pay you for the spare muffler + shipping. Was just hoping someone like myself had one laying around gathering dust like some of my O.S. stock mufflers are out in the shop.
Kurt
AMA# 794291
Saito Club #121
Hide Signatures
(in reply to w8ye)
       Post #: 8
RE: Stock muffler for ST G-2300 ? - 11/30/2005 5:47 AM
Sturtz
Score: 100
Status: offline
Thanks Mike. Got your PM.
One stock G-2300 muffler sold.
Kurt
AMA# 794291
Saito Club #121
Hide Signatures
       Post #: 9
RE: Stock muffler for ST G-2300 ? - 11/30/2005 6:50 AM
seanychen
Score: 105
Status: offline
Oh, oops. You already got one. Ignore my PM reply.
Hide Signatures
       Post #: 10
RE: Stock muffler for ST G-2300 ? - 11/27/2012 8:53 PM
IFLYSLO
Score: 100
Last Login: 5/20/2013
Status: offline
I need one also. Anyone else has one for sale?
IFLYSLO
Hide Signatures
       Post #: 11
RE: Stock muffler for ST G-2300 ? - 11/27/2012 10:29 PM
geeter
Score: 108
Status: offline
the j-b weld won't hold up long. vibration and heat and fuel and oil will get to it pretty quick. better get a new one or a pitts muffler that will fit. i have been through this before myself. your repaired muff can break or crack in the air causing a lean condition and the engine will quit causing a dead stick. i guess you know all this.......just trying to help............RON
Hide Signatures
(in reply to IFLYSLO)
       Post #: 12
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> Stock muffler for ST G-2300 ?
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.328RCU1
