Geistware
GA, USA Status: offline
If you are using two wall warts, then you have two transformers and the grounds being connected are electrically the same. It should not make a difference. Think of it as the common is connect to the return of the transformer which is connecter to the ground lead. If you ohm them out (with power off) you may find that they are all connected. NOW, if you ran off of negative voltage, I don't think it would work!
_____________________________
Aircraft Proving Grounds http://www.rcaircraft.net/ Information on the building and flying of Radio Control Aircraft. Site for hobbyist in the R.C. Aircraft modeling world.
