Geistware
GA, USA Status: offline
Set your charge rate to C/10 250 for both packs. Set the pack capacity to 2500maH for both packs. THen charge. It will either peak or auto shutoff. Both conditions are OK. If you want to set the trickle, I would do it at C/20 or 125maH for both packs. If you want to leave it on for an extended period of time, I would reduce the trickle to about 50ma - 75ma quote:
ORIGINAL: Bass1 I have a few questions. I have a couple of new NIMH 5 cell battery packs (2500 and 2700 mah). I want to give the new packs a C/10 formation charge. How do you set up the Accu cycle Elite to perform this task? Also, I've been using a TME auto trickle with my wall warts to trickle charge all my nicads, Is the appliance timer a better option? I haven't purchased the Accu Cycle Elite yet and was wondering if there is something better with dual ports? Thanks in advance for any insight.
_____________________________
Aircraft Proving Grounds http://www.rcaircraft.net/ Information on the building and flying of Radio Control Aircraft. Site for hobbyist in the R.C. Aircraft modeling world.
