air mail rcu
PA, USA Status: offline
quote:
ORIGINAL: britbrat quote:
ORIGINAL: jamieduff1981 While most of you are right with regards to the physics you're all misreading the question. The question includes a limit (which in reality would be impossible to enforce). Read the question again, understand that the limiting clause means that the wheels can never be allowed to move faster than the belt, and then appreciate that in reality, by opening the throttle you are breaking the rules of the question. In order for the plane to gain forward speed, it's wheels must go faster than the belt in order for the wheels to make headway on the belt. No-body says airspeed is linked to the wheels. The wheels are important because the question locks their speed to that of the belt. Once again, by moving forward on the belt the question rules are broken. This is physically impossible, and in real life the plane would move forward regardless, but as far as this question is concerned, the plane cannot move (through worded limitations, not physics). As has been previously posted, not being able to move forward does not preclude take-off. The belt friction will generate a moving airstream that will eventually exceed the aircraft's stall speed. It will then be able to lift off & immediately accelerate in ground effect to actual flight-speed. ---and no baloney about bearing friction -- if you have a magic belt, you also have frictionless wheel bearings. It IS going to fly. Interesting. If the belt generates a airstream under the wing wouldn't that be a low pressure airstream? If so the wing would move towards the low pressure and the plane would stay on the belt. Either way the plane does not fly.
< Message edited by air mail rcu -- 1/10/2006 11:55:05 PM >
_____________________________
Take-offs are optional. Landings are mandatory.
