RE: Can It Take Off??
Tower Hobbies
Logged in as Guest
  Printable Version
Align T-REX 450SA ARF
Seller:  Erick Royer
Details:   $150.00   |  8/27/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Aerodynamics >> RE: Can It Take Off??
Page: <<   < prev  14 15 16 [17] 18 19 20 21 22 23   next >   >>
Login
RE: Can It Take Off?? - 1/12/2006 9:01:37 PM
britbrat
Status: offline
quote:
ORIGINAL: Rat1
quote:
ORIGINAL: britbrat
quote:
ORIGINAL: dick Hanson
what turns the wheels ?
forward motion
no forward motion=
no turning of wheels
not even a teensy bitsy bit -
Baloney -- boundary airflow alone would do it with the plane sitting there stationary staring you in the face while the belt whirls like mad.
However ---- the question said "Imagine an airplane is on the beginning of a massive conveyor belt, as wide and as long as a runway, and intends to take off. The conveyer belt is designed to exactly match the speed of the wheels at any given time, moving in the opposite direction of rotation. "
The assumption that it can't move is false -- there is no restriction on forward motion -- the only constraint is that the belt will match the speed of the wheels when the plane moves.
The plane will easily fly.
If so then how is it going to fly if the wheels are not rotating faster then the velocity of the counter rotating conveyor belt. The only way it is going to make airspeed is if the wheels spin at a faster velocity then the counter rotating belt.
Wheelspeed = 20 Belt speed = 10
20-10=10
Here we have a positive forward movement or airspeed of 10
Here is what we have to have according to the rules of the question
20-20=0
Now we have a forward movement or airspeed of 0. We all know that an aircraft with no airspeed is nto going to fly muchless lift off the ground.
Baloney again -- the wheels & belt move synchronously. Read the question -- there is no constraint on forward motion -- the magic belt instantly matches the wheel motion & the plane doesn't give a damn what its wheels are doing.
(in reply to Rat1)
       Post #: 401
RE: Can It Take Off?? - 1/12/2006 9:20:45 PM
Liberator
Status: offline
Actually no it doesn't. When the prop creates thrust something must be done to this force. You think the conveyer will spin backwards and the plane will stand stationary. In that scenario, the plane will advance and take off. If the conveyer tries to move with the plane (the only other option), then the wheels stay still, the entire plane moves forward until it attains lift off speed.
Either way the plane flies.
_____________________________
One man's crash is another man's carefully planned landing maneuver.
(in reply to Rat1)
       Post #: 402
RE: Can It Take Off?? - 1/12/2006 9:37:46 PM
Liberator
Status: offline
"Tell me how the plane ever gets any forward motion? Remember the belt is moving backwards at the the same speed the plane is rolling forward. Who cares how much thrust there is. The fact that the wheels aren't the driving force makes no difference here.The only way a real plane moves forward on a runway is because the runway is not moving under it. Without a headwind you need the groundspeed to get airborn. You can put a Merlin on a tricycle but as long as the reverse belt speed is equal to the forward motion you will always be at a standstill as you have ZERO ground speed. You only have a screaming prop and a moving belt...no more no less. Heck we did this in high school with electric motors and prop rods."
You can't ignore the thrust. I know that you want to to keep things simple, but that dog wont hunt. (no matter how big the phone booth is)
The fact that the wheels are not the driving force is makes all the difference in the world. Again the thrust monster rears its ugly head.
"The only way a real plane moves forward on a runway is because the runway is not moving under it. " What?
Actually the only way a real plane moves on a runway is if it is either getting pushed or pulled by a thrust inducing device (read motor).
"You can put a Merlin on a tricycle but as long as the reverse belt speed is equal to the forward motion you will always be at a standstill as you have ZERO ground speed. You only have a screaming prop and a moving belt...no more no less. " This only applies if the wheels are the driving force, not if there is a different thrust parameter at work. (read prop or jet) not axle and transmission.
Uhh no ya didn't.
(in reply to Tim Wiltse-RCU)
       Post #: 403
RE: Can It Take Off?? - 1/12/2006 10:13:25 PM
dick Hanson
Status: offline
(rimshot )
I am watching you
Libby
(in reply to Liberator)
       Post #: 404
RE: Can It Take Off?? - 1/12/2006 10:13:40 PM
jamieduff1981
Status: offline
That's the point. The plane WOULD fly if you tried this in real life.
The question is worded to mathematically state that the belt speed and the wheel speed must always match.
Mathematically - they are locked together. What would really happen is now irrelevant, as this question is an issue of mathematical logic.
The plane cannot move at all without it's wheels moving faster than the belt. The belt cannot move unless the wheels do. The wheels cant move unless the plane initially moves over the stationary belt . If the plane does move (and there's no physical reason why it wouldn't) then it's wheels momentarily go faster than the belt.
Thus the belt speed does not equal the wheel speed and thats it disqualified.
I know the plane would continue merrily down the runway/belt/whatever. It would gain forward speed relative to a fixed reference point. It would fly.
The point is that by now the question is over. The result doesn't matter. Nothing can move without defying the wheel speed=belt speed statement.
(in reply to dick Hanson)
       Post #: 405
RE: Can It Take Off?? - 1/12/2006 10:20:06 PM
dick Hanson
Status: offline
OK now--- how many of us have said that -
do you get the idea that this is an excercize in futility?
I am watching you
Libby
(in reply to jamieduff1981)
       Post #: 406
RE: Can It Take Off?? - 1/12/2006 10:39:43 PM
Rat1
Status: offline
if the plane does not go forward - what starts yer belt?
if it goes forward -- it takes off -
If it goes forward then the wheels have rotated at a velocity that is greater then what the belt is turning. Then you have this
1-0=1
This is positive movement. This breaks the rules of the stated question as the belt is supposed to exactally match the wheelspeed at all times. The conveyor has failed its job that it was designed to do.
Oh and swearing and cursing is not going to make the "Yes" answers correct.
Atving is my first love.
2001 Polaris Magnum 500 all set up to run deep in the bogs.
       Post #: 407
RE: Can It Take Off?? - 1/12/2006 11:14:17 PM
mesae
Status: offline
This is one of the best and simplest explanations of all.
"The purpose of time is to prevent everything from happening all at once."
       Post #: 408
RE: Can It Take Off?? - 1/12/2006 11:46:46 PM
dick Hanson
Status: offline
Did I put a curse on this gag?
It is an accursed riddle -as stated.
I am watching you
Libby
(in reply to mesae)
       Post #: 409
RE: Can It Take Off?? - 1/13/2006 12:55:33 AM
Rat1
Status: offline
I am putting up a quick pic I made. Do not laugh OK. it took me all of 5 mins to create it.
quote:
Imagine a plane is sat on the beginning of a massive conveyor belt/travelator type arrangement, as wide and as long as a runway, and intends to take off. The conveyer belt is designed to exactly match the speed of the wheels at any given time, moving in the opposite direction of rotation.
There is no wind.
Can the plane take off?
Ok Now
A is our conveyor speed
B is our wheelspeed
C is our aircraft movement in relation to the world around it
D is our thrust
Ok we will start everything moving so to speak
We have the A turning at 20 RPM and the B turning at 20 RPM (I made the "A" drive so that 20 rpm would be equal to the "B" 20 rpm)
Our thrust is 20 (just an example)
What is our aircrafts movement in relation to the world around it????
If it is not moving then what numbers do we need to change or leave alone to make the aircraft move forward in relation to the world around it????
Click to see fullsize image.
Click for fullsize
< Message edited by Rat1 -- 1/13/2006 12:56:40 AM >
       Post #: 410
RE: Can It Take Off?? - 1/13/2006 2:22:07 AM
old git
Status: offline
quote:
ORIGINAL: bentwings
There is no wind.
This is a THOUGHT experiment and need not inhabit reality, to those who do not understand the concept of a thought experiment I suggest you look up "Schrodingers Cat" in your physics texts.
old git
(in reply to bentwings)
       Post #: 411
RE: Can It Take Off?? - 1/13/2006 2:25:17 AM
David Cutler
Status: offline
quote:
ORIGINAL: Liberator
You can't ignore thrust. At least thats what I told her.
... and did she believe you?
-D
       Post #: 412
RE: Can It Take Off?? - 1/13/2006 4:23:22 AM
cyclops2
Status: offline
As the Blimp races the engines to 1/2 power and lifts gracefully off of the landing wheels, a hush falls over the conveyor belt.
< Message edited by cyclops2 -- 1/13/2006 4:24:22 AM >
(in reply to David Cutler)
       Post #: 413
RE: Can It Take Off?? - 1/13/2006 5:38:52 AM
PowerPlay
Status: offline
Say What?
Click for fullsize
(in reply to Rat1)
       Post #: 414
RE: Can It Take Off?? - 1/13/2006 9:51:39 AM
Aussie Damo
Status: offline
LOL, great pic
this is true, a blimp is a form of aircraft, the the a/c would fly, this is the same for any VTOL a/c like the Bell X-22
So, YES the aircraft will fly
1/2A Aussie balsa basher
ps. not always with tools though
(in reply to PowerPlay)
       Post #: 415
RE: Can It Take Off?? - 1/13/2006 10:50:08 AM
CHassan
Status: offline
quote:
ORIGINAL: Rat1
quote:
ORIGINAL: CHassan
quote:
ORIGINAL: Rat1
quote:
ORIGINAL: CHassan
SO one is rotating clockwise the other counter clockwise.
Do you still think 1= (-1)?
Why is this important???? No 1 is not equal to -1 as 1 is a greater number then -1.
Can 1-1= a number greater then 0???? For the aircraft to make forward movement on a conveyor that is spinning at a velocity in a counter clockwise direction its wheels would have to be free rolling at a velocity greater then 1 in a clockwise direction. Once this happens the the conveyor has failed to do what it was designed to do and that was to exactally match the wheel speed at all times.
As I said forward movement/Airspeed is =C in A-B=C
A is your wheelspeed in terms of velocity
B is your conveyor speed in terms of velocity
C is your airspeed/forward momentum/run out speed in terms of velocity
A-B=C
If 1 does not = -1 then you broke the rules of the question by using these measurements.
Not really. If the wheels forward rotation is clockwise and the conveyors forward rotation is counter clockwise then I have not broken the rules at all. They are both rotating in their forward rotation velocity of 1. The only difference is they are opposite of each other (clockwise vs counter clockwise). Get my drift????? Oh well everyone else understands it.
Oh so sine the absolute values are 1, then you can just throw a (-) in where ever you like? Not only that, but then pick and choose between the planes speed and the conve
