jamieduff1981
Joined: 12/29/2005 From: ELLONScotland, UNITED KINGDOM Status: offline
CHassan, glad you got 44.5 You ask "how do the wheels ever get rolling" or words to that effect. That's the sceptic's arguement. If the wheels roll, the belt matches it, right? So either: The plane initially moves and the wheels roll and after a short delay the belt reacts - hence the belt hasn't matched the wheel speed and the whole exercise has been a waste of time Or: the belt acts instantly. In this case, as soon as the plane tries to edge forward, thanks to it's thrust against a static atmosphere (on an initially stationary belt) the belt tries to match the wheel speed, both wheel and belt speed go instantly to infinity (because the plane's thrust doesn't go away and the plane will continue to try to roll forward faster than that belt below it). Once it reaches infinity (which can't really happen) everything equals infinity and it's still been a complete waste of time. Only if the belt fails to match the wheel speed can the plane actually make any progress and gain airspeed in a near static atmosphere which is independant to the belt. The key to the sceptic arguement is the "exactly matches" statement regarding the belt and the wheels. This can't happen as the belt will always be reactionary. Even mathematically it's reactionary because the wheels wont move until the plane moves. If the plane moves then it's wheels have gone faster than the belt. Nothing else really matters. There will be friction from the wheel bearings, gyroscopic forces from the wheels, a moving boundary layer from the belt etc etc etc. That's all true in real life. The question is hypothetical though. It has to be because it states absolute conditions. The word "exactly" makes sure of that. None of these real life limitations matter because the experiment fails as soon as it begins. In other words, it's a non-starter!
