mesae
OK, USA Status: offline
quote:
ORIGINAL: ptulmer ..These same people probably think the downwash from the wing propels the airplane into the sky like rocket thrust... First, the belt will have very little influence on the plane (none, if bearing friction and tire momentum are ignored), in case there is any doubt about my position on the matter. Now, your apparently facetious statement above isn't entirely untrue: Rocket thrust is a force in reaction to the acceleration of gases. Propeller thrust is a force in reaction to the acceleration of gases. Wing lift is a force in reaction to the acceleration of gases. All three statements are true. Also, for kbear who wrote that an iced lake isn't moving: If the airplane is facing west, at rest with respect to the lake, then as it begins its takeoff roll, it will accelerate with respect to the air over the lake, but it is decelerating with respect to a non-rotating reference frame at the center of the earth. So while it is true that the lake isn't moving in response to the airplane, it can be considered to be moving under the airplane, in the direction opposite the takeoff run, just as truly as it can be said that the airplane is moving with reference to the lake and/or the air over the lake. Put another way, an airplane flying 1000 ground mph westbound over the equator, is staying approximately stationary with respect to a non-rotating reference frame at the center of the earth, while the surface of the earth rotates under it.
_____________________________
"The purpose of time is to prevent everything from happening all at once."
