David Cutler
CA, USA Status: offline
quote:
ORIGINAL: Flyfalcons The problem is for the airplane to take off, it needs to be moving forward (no wind). If the plane is moving forward, then the belt would not be spinning at an equal rate to the tires. The belt could be travelling at 1,000,000 mph or zero, and the wheels spinning at 1,000,000,000 rpm or zero. It makes no difference to the airspeed of the plane, and therefore the air passing over the wing. You are confusing groundspeed with airspeed still. -David C.
