kriegsmacht
OK, USA Status: offline
Heres what would happen in the real world, no wind, plane sitting stationary on the belt, engine idling. Gradually apply full throttle and the plane would quickly move forward. At this point the sensor unit would activate the belt drive motors. I am still unclear which way the belt is designed to turn, but I will cover both instances. 1. Belt goes same direction as plane body: Plane accelerates forward, wheels not turning, and measurably but not noticeably sooner than a normal takeoff, lifts into the air. If it is a tail dragger, you will not have to compensate for left pull (P-factor) because the wheels will not be rolling. The nose, on a plan with a free castering tail wheel will yaw left for a moment then straighten up before plane lifts off normally. 2. Belt goes opposite direction of plane body: A measurable decrease in acceleration due to wheel bearing friction, but with quality bearings it wont be very noticeable. Steering of either a tricycle or tail dragger will be greatly amplified and quite squirrelly. If you don't tip over or something it will take off normally when it reaches its normal takeoff speed. Gyroscopic effect, and aerodynamic forces of spinning wheels would not be noticeable. In other words the plane would take off fine, the only difference would be steering on the ground, and it would be a big difference.
< Message edited by kriegsmacht -- 12/6/2005 12:26:59 AM >
