DLSmith2
TX, USA Status: offline
I think you might be able to visualize the problem better if you think of a full scale plane like a Cessna 152. If the 152 begins flight at about 60kts airspeed it doesn't matter what rate the tires are turning, other than like BMatthews said, the overheated bearing problem, or surface friction. You can lock the wheels of the Cessna, point the nose into a 60 kt wind, pull back on the yoke and the plane will lift off, because the airspeed over the wings will provide the lift, and the wheels aren't turning at all. The question is misleading, because it implies that the speed of the wheels, or ground speed, determines an aircraft's ability to take off, instead of the airspeed. If you take off from a grass runway that hasn't been mowed in a while, the friction of the long grass can increase the take off distance by 10%. This is because the grass prevents the plane from reaching the airspeed it needs to lift off, until the plane has gone a little farther. Wheel friction on the conveyor belt may increase the length of ground roll necessary to get 60kts of wind going over the wing, but that doesn't matter because it's a conveyor belt, right? Interesting question, huh? Blue skies, DL This is a job for the MYTHBUSTERS!!!
