crashcrash -> RE: HeliMax MX400 Problems (1/31/2008 3:41:01 AM)
MX-400 review: Got it in the mail 01/26/08, completed 01/30/08. First.....what I've found: 1. Weak points a. vertical/horizontal stabs, flybar paddles, and tail rotor blades are made of a compressed granular substance like salt consistancy and they break easily. b. the rotor head components (and I mean all of them) are weak, in this case aluminum is not bling and I'm checking on T-Rex compatability of plastic head parts. c. tail rotor blade grip ball links are weak and break easily. d. tail rotor servo push rod is too short and has to be extended by 3/4". e. electronics installation of RX/Gyro/and ESC are a bear because of limited space. The motor is mounted "pinion up" taking up room in the lower frame area. f. the anti-rotation bracket is weak and breaks easily. g. canopy mounting pins break easily because of being a carbon composite attached by screws to the frame (T-Rex replacements here). h. Suspect areas are the brackets that hold the tail boom and the belt drive gear assembly brackets, but time will tell. i. battery tray....needs something done, it's too short. I'm thinking of making a slanted aluminum one. j. I feel the stock rotor blades are a tad too long. k. my batteries are now too small (1500mAh 15C's). l. parts are a little pricy. m. I don't like the skid poles n. kit come to my door "pre-broke", and NOT the fault of the seller. Keep in mind, I installed a 120deg CCPM upper instead of using the 180deg upper because of the DX6. The build other than the above listed problems, went OK. I used a tail rotor grip off the HBKII and modified it a bit to make it work, and it does. T-Rex parts will work when I'm ready to replace them, but I wasn't gonna wait for parts. Because of the way the rudder servo mount's, I had problems with the gyro at first because I didn't take into consideration it's backwards from the HBKII, and it took a bit to figure out why it wouldn't work and I finally got it. Because of the upper install, I had to start from ground zero on all settings, this took a long time. There were so many things that were out of whack, sometimes it become confusing. What I did was to address one problem at a time instead of jumping from one to another to another....it finally come together. Now that all issues are addressed and it's dialed in, it's very nice and I like it. I would compare it to a scratch build instead of ARF. I still got work to do on the canopy because I screwed up the paint job, but I had the one you see in the drawer, and it'll work till I finish the original canopy. Good points: a. the frame is very solid b. servos are mounted into the frame using screws and nylon nuts c. nearly all linkages are metal ball d. lots of spare ball links (M/F) come with this kit. e. it flies way more stable than anything I've owned to date including the HBKII. f. easier for me to see than a 300 class heli. g. tail response even with the standard E-Sky servos is awsome but it may be my setup. h. awsome headspeed and power....I had to tame it a bit. i. price....$60.00 to my door (why I bought it). My opinion overall....a lot of work but in the end, a very nice heli. I wouldn't recommend anyone who has trouble setting these things up buy one. If a person is not mechanically inclined, it's also not a good idea to buy one. I extended the rudder push rod by welding an extension to it (.047" x 2), and using shrink tube to cover the weld (I used to weld soda cans together for fun in the Navy). Basically, I got what I paid for, and I'll have to upgrade parts as I go along (flybar paddles, etc). I could have bought a Belt-CP for $120 to my door and done a lot less work. It's a project bird and worth about $60...LMAO, but it flies GREAT. IMHO.....buy the Belt-CP or something else unless you want to tinker and build. Note: a special thanks to the thread starter and all you guys who posted, you saved me a lot of work and grief. As you can see...I ordered the aluminum center hub right out of the gate. The 120deg CCPM upgrade kit included the aluminum swash. The tail rotor grip assembly is off a HoneyBee King v2 and it works with minor modifications.
