RE: HeliMax MX400 Problems (Full Version)
All Forums >> [RC Helicopters] >> Electric RC Helis
Message
planebuilder66 -> RE: HeliMax MX400 Problems (3/12/2008 10:20:07 PM)
I can't wait to put mine together, right now it's sitting in the box awaitting componets. I have most of the aluminum head parts and a few spare upper crash kits but I will need to change it over to eccpm or try it as is. Can't choose which way to go on that. What motors are you guys running, I was going to run the align bl430 I had but I realized that I wore it out, the bearings are failing in it, causing a high pitch squeal from the stator rubbing on the housing.
crashcrash -> RE: HeliMax MX400 Problems (3/12/2008 11:39:51 PM)
quote:
ORIGINAL: planebuilder66
There are several motor choices but anything that works in the T-Rex will work on the MX400. I did the CCPM upgrade and even if I buy another MX-400....it too will get the upgrade. The reason on the 120deg CCPM upgrade...a lot less moving parts since it's direct servo to swash, and it allowed me to fabricate an aluminum battery box and I mounted it slanted which fits right in the canopy without a hassle. I am truly impressed with the MX-400 AFTER I did all the parts changes and mods...it's a stout heli.
planebuilder66 -> RE: HeliMax MX400 Problems (3/13/2008 2:59:51 AM)
Wow, I actually got a decent answer and honest. I think the jgf motors look right and the eccpm is a no brainer. I'll get it this weekend along with a 401 and hs65's.
crashcrash -> RE: HeliMax MX400 Problems (3/13/2008 3:39:17 AM)
Welll....if you want to save a bunch of CASH (LOL), this is what I use and it all works GREAT.
*0704A HHG by E-Sky $36 to my door
*standard 8G servos from E-Sky $6.00 ea before ship
* you can also use HS-55's if you have a programmable radio (DX6/DX6i/DX7/Futaba 6EXH...etc)
www.jaghobbies.com
He ships fast, and prices are fair.
Got my HHG off E-Bay...did pretty good. The MX-400 works good with any of the servos/gyros used on the King v2. After all, other than the motor/batteries/and ESC, the MX-400 is basically a King v2 with an aluminum frame (bonus), and it's physically a little bigger and weighs more.
Page: <<   < prev  1 2 [3]
Valid CSS!
SITE MAP!   : :   FORUM RULES
0.1103516
