RE: Carden Cuda Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: Carden Cuda Build
Page: <<   < prev  1 2 [3] 4 5 6   next >   >>
Login
RE: Carden Cuda Build - 1/5/2006 1:38:35 AM
ibow24
Status: offline
I went back and forth on weather to leave the tip extension or make a full length aileron. I decided to go with the tip extension but will probably live to regret it.
Like Kent said, I can just see the very first time I ding the plane it will be right on those tips !!
Good luck with your build Kent, Keep us updated on progress.
Steve
(in reply to Flyin Woodbutcher)
       Post #: 51
RE: Carden Cuda Build - 1/5/2006 1:54:13 AM
Flyin Woodbutcher
Status: offline
Thanks Steve , I"ll start as soon as I get my 35% Cap finished. As for the tips I cap mine with 1/8 lite ply. Makes them rit durable.
Kent
(in reply to ibow24)
       Post #: 52
RE: Carden Cuda Build - 1/5/2006 3:22:44 AM
RobT
Status: offline
What tip extensions . . . the ailerons go all the way to the tip (and the elevators have a counter balance) At least they do on mine now. As for the round tips . . . I liked to build them for a change . . . had fun working and whittling wood! plus it is good practice if you want to do the Yak . . .
I have monokoted the wings, stabs and fin . . . pictures to come
Rob
       Post #: 53
RE: Carden Cuda Build - 1/6/2006 12:28:26 AM
ibow24
Status: offline
I thought I would show how I control the tailwheel. If someone has a better way please show me or tell me.
I cut a notch in the bottom of the rudder and then add a small piece of 1/8" ply. I then add 2 small screw eyes near each edge of the rudder and then attach the springs (with a piece of pull-pull cable and crimps) from the tail wheel arm to these screw eyes. It's simple but it does add some weight.
attached are pictures of the ply piece in my Cuda rudder and the finished tail wheel on my 35% Extra
Steve
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to RobT)
       Post #: 54
RE: Carden Cuda Build - 1/6/2006 12:42:17 AM
Flyin Woodbutcher
Status: offline
nice and simple I say.
Kent
       Post #: 55
RE: Carden Cuda Build - 1/7/2006 3:50:42 PM
ibow24
Status: offline
OK..This morning I pulled my first and hopefully only DUMB A$$ moment of this build.
Last night I drew the cut lines for all the bevels on the control surfaces and figured that was a good place to quit for the night.
This morning I went down, set up the bad saw (yeah I use the band saw the cut the bevel to rough shape)
got one of the elevator halfs out and ran it through both sides...nice, looks good right.
too bad I didn't drill hinge holes BEFORE I did that !!!.
Oh well, at least the location was marked. I started with a tiny pin drill and worked my way up.
Then finished with a sharpened piece of 3/16" dowel.
at least I started with the stabs and not the wing.
Steve
       Post #: 56
RE: Carden Cuda Build - 1/7/2006 3:56:00 PM
zzw26n
Status: offline
Keep things going Steve ........... it's the small things that add up, good catch, lesson learned!
       Post #: 57
RE: Carden Cuda Build - 1/7/2006 4:09:33 PM
jmiracle
Status: offline
It's always the details that screw things up!! At least it wasn't a major problem.....like when the power went out while I was vac-baggin a wing core!!
quote:
ORIGINAL: ibow24
Steve
       Post #: 58
RE: Carden Cuda Build - 1/7/2006 11:15:31 PM
ibow24
Status: offline
That's a problem. I work for the local power company...that's why I own a generator
(in reply to jmiracle)
       Post #: 59
RE: Carden Cuda Build - 1/9/2006 9:25:58 PM
ibow24
Status: offline
Last night I started to cut out and fit the bottom deck. For some reason it was short. When down on the bottom of the fuse truss it only came up to just above the bottom of the motor box. I added a strip of 1/8 balsa to the bottom deck and
and now when I add the 1/4" sheet to the bottom of the motor box and shape it will blend a lot nicer.
All the surfaces are hinged and beveled. I need to had the control hard points yet
This evening I plan on setting up the wing incidence. I'm kind of running out of things to do until I have the engine and servos. They should be shipped this week.
       Post #: 60
RE: Carden Cuda Build - 1/10/2006 2:16:58 AM
RobT
Status: offline
I haven't been posting as much as I should, but here is how I get the canopy to be flush with the fuse side:
Take a piece of scrap canopy material, and glue some sandpaper to it. Use this as to determine the depth to sand the hatch recessed past the fuse sides.
Click for fullsize
Click for fullsize
       Post #: 61
RE: Carden Cuda Build - 1/10/2006 2:20:34 AM
RobT
Status: offline
Wing ready for covering: You can see one of my "tricks here" The use of an ironing board to work on while covering
The Second tip is to STRETCH the covering as much as possible to prevent wrinkles. Not the picture with it covered is BEFORE the use of a heat gun. Just the edges are tacked.
Click for fullsize
Click for fullsize
(in reply to RobT)
       Post #: 62
RE: Carden Cuda Build - 1/10/2006 2:31:03 AM
RobT
Status: offline
I didn't take any pictures of it but I had a great idea today and it worked like a charm.
I used a photocopy of the side view of the plans to cut a pattern of the root of the stab. I then positioned this on a piece of monokoke and cut the stab root out of the piece I was going to use for the side. I was then able to do the sides in one piece without any seams around the stab area.
Rob
(in reply to RobT)
       Post #: 63
RE: Carden Cuda Build - 1/10/2006 5:07:29 PM
ibow24
Status: offline
good tips. I like the iron board too...never thought of that.
I'm fitting the wings and installing the 1/8" root today. It's not going so well, I'm having a tough time getting a real nice tight fit against the fuse side. Just takes time pulling the wing off, sanding a little, put it back on..blah blah blah, you've all been there.
Steve
(in reply to RobT)
       Post #: 64
RE: Carden Cuda Build - 1/10/2006 8:38:56 PM
ballistic1
Status: offline
What I do for getting a perfect fuse to wing root fit is this --- using a spare wing tube socket--(there is a small piece left over) - and the wing tube put the unsheeted wing against the fuse in its approximate position and carefully sand the core to fit against the fuse
if you do this before sheeting the wing and installing the root cap you will end up having not having to sand the root cap -which
is critical for a strong wing
I guess you have to have your componets put together in a specific order to be able to do this and its too late now ,
but in the future you will see that this works great
Frank
