MJD
ON, CANADA Status: offline
Just because a plug glows does not mean it is fine, however as long as you have power connected it is less of an issue compared to once the glow driver is disconnected. But, remember that plugs do deteriorate - they function by catalytic action on the methanol, and if the plug element is covered with deposits running may be erratic, however the plugs will still glow happily with power applied. One obvious clue is, do your motors slow down when you remove glow heat? If so toss the plug, if it is old. If it is new, then the heat range is off, but let's not consider that for the moment, as you should still get the motor to start fine with power connected. When in doubt, try a new plug. Bad plugs can manifest themselves in mysterious ways. As downunder suggests, a low panel battery or miserable connections can cause grief too - One sure-fire way I know my battery is getting down when my motors will not fire until I take my finger off the starter switch! As to not running your engines for 3-4 months, that doesn't matter unless you've let fuel congeal in the carb or a bunch of rust build up in the engine from not clearing it out and popping in some after run oil. My engines sit all winter, and when I fuel them up and prime them in spring, off they go. MJD
