RE: JTEC MUFFLERS AND ACCESSORIES
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> JTEC / RADIOWAVE Support >> RE: JTEC MUFFLERS AND ACCESSORIES
Page: <<   < prev  1 [2]
Login
RE: JTEC MUFFLERS AND ACCESSORIES - 3/13/2007 1:18:54 AM
LANNYBOB
Status: offline
yep i flew it again today and the muffler did not come loose, so its a fix.
_____________________________
LIVE LONG AND FLY LOW
ITS NOT THE END OF THE WORLD BUT YOU CAN SEE IT FROM HERE
(in reply to LANNYBOB)
       Post #: 26
RE: JTEC MUFFLERS AND ACCESSORIES - 4/16/2007 9:52:49 PM
LANNYBOB
Status: offline
ive flown it six times since my new jtec muffler and no more problems with it coming loose. you want the best you got the best, "jtec"
       Post #: 27
RE: JTEC MUFFLERS AND ACCESSORIES - 10/21/2007 1:01:34 AM
Pepito
Status: offline
Hi Al,
I just bought a used Aero-Tech P-51D "Old Crow" without the engine. I've been told that the previous owner put a ZDZ80 in it. I have a ZDZ80 but there is no way the Pitts muffler will work in this airplane. Do you have any suggestions? Apparently this plane flew with the ZDZ80!
Thanks!
       Post #: 28
RE: JTEC MUFFLERS AND ACCESSORIES - 10/22/2007 2:53:03 PM
al
Status: offline
Pepito.
Take some low resolution pictures of the engine mounted from the side and the rear (head to firewall) if you can take some measurements also we can see what you have to work with. I sure we can get something done for you.
AL
JTEC/RADIOWAVE
FUTABA
(in reply to Pepito)
       Post #: 29
RE: JTEC MUFFLERS AND ACCESSORIES - 10/25/2007 2:47:35 AM
Tired Old Man
Status: offline
al,
I have a Brison 6.4 that had been using the 45 degree Bissons mufflers and I have a BME 115 that has a stock set of BME mufflers. I would like to replace the Bisson mufflers on the 6.4 with something similar but "locally" made. The stock BME mufflers severely block access to the carb tuning screws so something needs to change in that area. The 115 is in a 2.6 Comp Yak. Do you have anything already done up that would fit the bill? Each muffler set would need a smoke nipple that could be removed and blocked when not used for smoke. Preferably with something that would thread into the nipple opening.
If you can''''t fix it with a hammer, you have an electrical problem.
(in reply to al)
       Post #: 30
RE: JTEC MUFFLERS AND ACCESSORIES - 10/25/2007 2:59:27 AM
Pepito
Status: offline
Thanks Al. As soon as I have it mounted I will take a photo. I just realized that with this large engine I need a shaft extension so I can keep the head as far back as possible !$%^&*%^*!
Thanks.
(in reply to al)
       Post #: 31
RE: JTEC MUFFLERS AND ACCESSORIES - 10/25/2007 2:12:54 PM
al
Status: offline
Pat Roy,
I am sure we can do something for both engines. We do not stock finished mufflers, this allows us to make changes when they are being built.
On the 6.4 we can make them pretty much as you want.
On the BME it would probably help if you could take some pictures of the problem area and send them to us so we can see how to improve access to the needles. It may take putting an access tube through the muffler.
send any pictures to sales@jtecrc.com
you can also call us at 704-799-1658
Al
JTEC/RADIOWAVE
FUTABA
(in reply to Tired Old Man)
       Post #: 32
RE: JTEC MUFFLERS AND ACCESSORIES - 10/31/2007 9:52:51 PM
Tired Old Man
Status: offline
Will do, and thanks.
(in reply to al)
       Post #: 33
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU1
