Ed Cregger
GA, USA Status: offline
quote:
ORIGINAL: Kweasel Supertigres 2300 is one of their finest engines since they have fixed the carb design of the early production models. You will have to spend a few minutes getting the low needle set. The cause of many problems that I see are from people using too large a tank mounted too far away, too large a prop, and sometimes too much nitro. These same people are also the most vocal about their sorry Supertigres. The 2300s large carb is sensitive to tank location and needs good muffler pressure, 9000rpm+, and around 10%nitro. [I use 5% coolpower] A 16oz tank will run over 10 min with a small mixture change as the tank empties. Popular or not its a very good engine at a bargain price. ----------- Additionally, before Super Tigre closed its doors, they stopped making the carb barrel with the proper groove machined in it for the G2300's needs. They substituted the barrel for the 4500, which had a different groove. The groove configuration affects the midrange mixture. Suddenly, what was a well behaved and excellent running engine turned into a nearly unusable paperweight. Mr. Reivers, of this group, has done extensive experimenting and posting on this group detailiing how to machine the proper groove into the barrel with a simple Moto Tool and a cut-off wheel. Hopefully, the newer Chinese versions have been restored to the proper groove configuration machined in the carb barrel. End of problem. How much faith do I have in these engines? I just bought a new one a while back. They are fantastic engines and they come embarrassingly close in power to the OS 1.60 FX at over $100 less expense.
_____________________________
Artisan "Flying models since the Fifties - I'll get the hang of this yet!!!"
