roychye
Joined: 5/15/2007 From: Adelaide, AUSTRALIA Status: offline
Hi JTspin. Thanks for your notice, i do found the controller in the games controller, it's name is ppm. Same as before, its status is ok even the tx is not connected, and i was not able to calibrate it I run the AA alkerine battery on the 22e transmitter, is it the problem of low power? but the battery level shows it's pretty much full. Or there is some setup needed on the tx??? i'm really upset because i cant play with my reflex xtr. If you have any suggestion could you pls tell me, i m considering getting a Esky simulator controller which costs 30 aussie dollar, if the tx still not gonna work.
