MBX5T Maniac
Joined: 12/21/2004 From: none, TX, USA Status: offline
Munch Munch. MMMM, popcorn The only reason the carb came off was because you didn't have it tightened enough. To set the mesh, m-e-s-h, you take a piece of printer paper, rip off a strip, and fold it in half so that the paper is essentially 2 pieces thick. Stick it inbetween the spur and clutch bell, and press the engine with your fingers against the engine. While pressing the engine, tighten the engine mount screw, until tight. That's how I do it, and I have yet to strip my spur gear
_____________________________
My toys: LST, Mini Inferno, XX-CR, GrassHopper, RC10, Rustler, MBX5T Prospec, Mugen MST-1
