Biodragen
Joined: 10/12/2005 From: Harvard, IL, USA Status: offline
I have had lots of issues with the ST at first and some they day I got it--crappy assembly. I have burned up clutch bearings after 2 runs, lost parts, broke rear arm once front upper right arm twice. One axle came (rear) snapped off in a race and I did not even touch a thing, next thing you see is the wheel geoing by the truck and I was ****??? This is what I have done and it has helped. The Shock towers are worth the upgrade---they are almost 1/3 thicker and stiffer. I also upgraded the chassis stifners to the rounded ones verses the flat. This made it more stiff and less flexing. The flex will mess with the mesh of the motor gears and center diff. Just give the truck a twist yourself and you will notice the flexing. Also I upgraded the center diff to alum. In addition to that I took it apart and put in 10,000 wt diff oil. This keeps the front wheels from spinning out. You could try to up the front shock oil to 70 wt first and see if that will do it. For sure add a rear wing to it...this helps to keep the rear down especially when jumping and allows for more control with breaking while mid air. I also put on shock boots to keep the shocks a bit cleaner. I also put in 45wt oil in the front shocks and installed the threaded adjustments at this time . The clutch shoes---take them off and put a thin washer on the posts and put it back together. This reduces friction and wear on the flywheel. Oh and dump the alum flywheel with the vented one, this helps cut down on it heating up. Also make sure you blow out the excessive grease in the clutch bearings other wise it will spin out onto the clutch shoes and make thing more difficult. www.avid.com is a good place to buy bearings at a $1 a bearing. Buy a dozen clutch ones and you set for a while plus it is cheaper than Sportwerks name on it. Keep a can of air like for PC's if you do not have a compressor and handy at the track---who really brings compressors with them. Use this to blow out the bearings. I also went down to 12 tooth on the clutch verses the 13t---little quicker. FYI FWIW Stock specs RTR Front and Rear shock oil 30wt Front Diff 1000wt Center Diff 7000wt Rear Diff 5000wt This is what I was told from Horizon. I hope some of this info will be useful to you.
< Message edited by Biodragen -- 12/15/2005 2:21:02 AM >
