JimCasey
TN, USA Status: offline
You have a clever water rudder installation. Full-size planes have retractable water rudders. Water rudders are only used for slow taxiing. Since, with R/C models, we would need an extra $ervo for a retractable water rudder, we generally do without. Imagine the airplane going fast, floats level, about to take off. You're just touching on the step. You REALLY don't want the water rudder in the water 'cause it'll slow you down A LOT. Now you're ready to take off and you haul back on the stick. The water rudder sticks in to the (30 mph) water an extra inch and a half. If you only have ONE water rudder, that drag is a pretty big off-center force trying to pivot the airplane away from a straight line. If you're quick, you can save it but it'll make for a ragged takeoff. If the rudder is no deeper than the step, when you haul back on the stick, the airplane can rotate 4 degrees nose-up before the water rudder touches. This, plus the 3 degrees of positive incidence you should have in the wing makes for a 7 degree angle of attack. You get enough of a bite of the air to make a nice takeoff. If you find that you need more bite from the water rudder, make it stick back further behind the float(s), not farther down. Water rudders on RC floatplanes help you taxi crosswind. It's possible to operate without a water rudder...just dial in all the travel you can get on the air rudder. If the motor is running, you get prop-blast over the air rudder and can steer with power and rudder. If the motor is NOT running, a water rudder does you no good anyway. Technique: To taxi into the wind, the airplane should do this with the elevator neutral and the motor at idle. To taxi downwind, hold full UP elevator, and add 2 or 3 clicks of power. The plane should be plowing along, trying to climb up on the step, pushing a lot of water, with the floats tilted upward as much as they will. This gets you (1) max rudder in the water, (2) the center of floatation of the floats is now behind the center of aerodynamic forces on the airplane, so the plane tends to weathervane downwind around the part of the floats that are in the water. To taxi crosswind: Hold full UP elevator, and steer the rudder in the direction you want to go. When the wind catches the air rudder, the plane will probably try to weathervane. Add power to turn downwind. Reduce power to turn upwind. Steer with the throttle. It really works!. My buddy Donnie has a beautiful Cub with twin water rudders. We tried to fly it one windy day. The water rudders were so effective that the airplane pivoted around them. When the wind blew, the whole plane pointed downwind, and we couldn't get it to turn back around for a takeoff. At max rudder deflection, it would just go a little sideways, but still downwind. If the water rudders were not so big, he could have given it a bit of down elevator and lifted the water rudders out of the water, and the plane would have weathervaned into the wind instantly.
_____________________________
Jim Casey/Seaplane Nerd http://www.smilesandwags.com/Floats.html
