RE: Anyone own a Warhead    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> RE: Anyone own a Warhead
Page: <<   < prev  202 203 [204] 205 206 207 208 209 210 211   next >   >>
Login
RE: Anyone own a Warhead - 4/29/2006 10:22 AM
86atrack4
Score: 100
Last Login: 2/11/2012
Status: offline
When u shut it down are u plugging the pipe stinger? This way floods the engine, and inturn is harder to start.pinching the fuel line is the proper way of shut down a engine.
quote:
ORIGINAL: Fire106
Hey guys....
Was just outside breaking in the new engine Hobby Sevices sent me the other day. Checked the temp halfway through the first tand and it was 350......i let it cool....richened the HSN and ran the rest of the tank at 280. Had trouble starting for the next tank....glow plug failed. Swapped it out and got 3 tanks done tonight........only problem im having is its flooding and hard to start. When i shut it down i can see fuel "bubbling" in the carb. To start in I have to remove the glow plug....clear the fuel from the motor, replace the glow plug but leaving it loose....then it will start. Im not sure if the way im running the fuel line is causing the problem. I removed the header tank.....fuel line runs from under the tank....up between the tank and the engine.......its loosely zip tied to the right side of the handle...then down to the carb ( i have the fuel port on the carb facing forward to get away from the throttle linkage )
Any idea's on why its flooding?
Sorry no pics.....I have to get going.....My girl is taking me out for my birthday tonight.....the other day she asked me what I wanted and when I said a Revo 3.3 she just looked at me and said " Is that one of the stupid cars" hmmph ......women
_____________________________
TNX pro 5.2 modded chassis with hyper .21 8 port, Jammin X1 crt pro with LRP Z.28 R
Hide Signatures
(in reply to Fire106)
       Post #: 5076
RE: Anyone own a Warhead - 4/29/2006 5:15 PM
ggomez
Score: 100
Last Login: 10/22/2006
Status: offline
OK Ash, The first thing we want to know in the Warhead forum is how does the Revo suspension & handling compare with the Warhead?
I have not found a truck with better suspension or better handling that the warhead.
My buddy just got the Revo & we did a little recing, his truck speed beat my warhead, but he kept flipping over & over.
My warhead was't tuned properly either & it is having some sort of tranny problems.
Take it easy,
Gil
http://www.rcpics.net/img/76879
quote:
ORIGINAL: Bill Plude
ash has a Revo now, he'll have to admit which is better.
Hide Signatures
(in reply to Bill Plude)
       Post #: 5077
RE: Anyone own a Warhead - 4/29/2006 10:19 PM
ford77id
Score: 100
Last Login: 6/30/2012
Status: offline
My bro in law with the savage has driven my warhead, and he's always wishing his savage handled like my warhead. Soon as the engine/transmission/cv shafts/radio are up to par on the warhead, it will be a great machine.
1 Duratrax Warhead 2 New Bright Rockcrawlers one mostly stock Savage 2 wheel drive. Vids: my username at youtube.
Hide Signatures
(in reply to ggomez)
       Post #: 5078
RE: Anyone own a Warhead - 4/29/2006 10:29 PM
HPI4LIFE
Score: 100
Last Login: 11/19/2007
Status: offline
I agree with ya ford77id. I just got the savage x and it rolls really easy compared to my warhead. But the x never stalls on me and I have hit the same objects in my yard with my savvy and nothing has broke just burnt up a spur gear this morning. I cant wait for the WH to get back from hobby services Im missin the old beast.
Hide Signatures
(in reply to ford77id)
       Post #: 5079
RE: Anyone own a Warhead - 4/30/2006 2:34 AM
DadtoaMarine
Score: 100
Last Login: 7/19/2006
Status: offline
Cyberhog,
How long has your WH been at Hobby Services? And, what did you send it in for?
Savage .25 w/3 speed and reverse, Warhead, Terra Crusher, 2.5R T-Maxx-Wide Track, XTM Mammoth MT w/reverse
Hide Signatures
(in reply to HPI4LIFE)
       Post #: 5080
RE: Anyone own a Warhead - 4/30/2006 7:07 AM
Fire106
Score: 100
Last Login: 12/21/2010
Status: offline
86atrack4..............i pinch the fuel line to shut it down.
Had a lot of problems today.......engine kept overheating and flooding......could not figure it out. I removed the engine this evening....cheked for airleaks....found none. Put it all back together and still had some daylight and fired it up again. It ran a little better put still had the flooding and overheating problem. Im looking for a good engine to replace the stock one right now but would still like to get this thing running right in the mean time. If all else fails I will just send the whole truck back to Hobby Services and let them figure it out.....
So is the STS .28 strong and reliable? I think im leaning that way for a new motor.....
Traxxas Slash stock...for now
Hide Signatures
(in reply to 86atrack4)
       Post #: 5081
RE: Anyone own a Warhead - 4/30/2006 9:05 AM
86atrack4
Score: 100
Status: offline
Is it all sealed up? u know thats a big problem with the .27
quote:
ORIGINAL: Fire106
Hide Signatures
       Post #: 5082
RE: Anyone own a Warhead - 4/30/2006 11:26 AM
DadtoaMarine
Score: 100
Status: offline
quote:
ORIGINAL: Fire106
Your overheating and flooding issue might be related. Did you check the slide opening in the carb? It is suppose to be no greater then 1mm. If you have to have the throttle trim set so that you engine idles with more then a 1mm opening then you need to adjust both the idle mixture and idle stop screw. I try hard to get it as rich as possible on the idle mixture as this helps cool the engine at idle. You'll have to play with it to get the best acceleration with the rich mixture but be sure you do not go lean.
Keeping the carb to a 1mm opening will also help with the after-shut-down flooding but you should also put a throttle return sping on the throttle servo. If you have not notice the throttle servo likes to return to center when it is powered off. This opens the throttle and allows for the carb to sphion off the fuel from the tank. Also you can buy these Revo Engine Shut Off Clamp to clamp off the fuel line instead of pinching it which will also stop it from flooding.
Hide Signatures
       Post #: 5083
RE: Anyone own a Warhead - 4/30/2006 1:57 PM
Bill Plude
Score: 100
Last Login: 10/27/2008
Status: offline
My RC store guy said the 1st care package from DT was an "anti flooding kit" it was going to have a piece of fuel line and a "Revo type" fuel line clamp! LOL
X1CRT.32Axial,Hellfire,3TMAXX,3.3,PICCO.21,OS.18,4Tec,3Revo OS18,3.3convo,3.3,2MT2 OS18,18SS, 2Buggies,5 RC18t,2 MiniTs
Hide Signatures
(in reply to DadtoaMarine)
       Post #: 5084
RE: Anyone own a Warhead - 4/30/2006 3:11 PM
barbarian1
Score: 100
Last Login: 2/13/2007
Status: offline
well bill, once again thanks for the revo 3.3 advice. yesterday was the funnest day i've had in a long time. 11 tanks of pure enjoyment! by the tenth tank i had this baby 95% of the way tuned in and doing wheelies on command! did a few accidental flips and cartwheels pretty hard and nothing broke either. Nice! VIVA THE REVO!
Hide Signatures
       Post #: 5085
RE: Anyone own a Warhead - 4/30/2006 3:41 PM
Bill Plude
Score: 100
Status: offline
Hide Signatures
(in reply to barbarian1)
       Post #: 5086
RE: Anyone own a Warhead - 4/30/2006 5:19 PM
aerialimage
Score: 100
Last Login: 8/26/2008
Status: offline
OK JUst recieved my warhead back after 1 month at Hobby Services!
On the second start the pull starter broke! SO Now they are sending me a new Pullstart! I have been playing with my Tmaxx 3.3 and waiting for my Revo 3.3 to arrive! IT is good to have the WArhead back and I have to say that I was real happy with Hobby Services other than the month it took. They updated my radio to the 3pm and it is a nice change! Thanks to all for sharing all the great info. I do not need to ask many questions as I have found most of my answers allready here!
On another note, I tried an electric heli! That was a good 15 seconds!
Back to trucks
T mxs 4-3.3 & 3-2.5 ,1-3.3 Revo,1Whead,2nitro evader st,Ofna pr comp,9.5,dmntr,1-Losi LST2,X1-CRT,savage 25&SS4.6 so far
Hide Signatures
       Post #: 5087
RE: Anyone own a Warhead - 4/30/2006 5:22 PM
Bill Plude
Score: 100
Status: offline
LOL @ the helo. My sons keep asking why not get a helo dad? Sure I can't keep a truck on the ground, how the hell am I going to keep a helo in the air! LOL
Hide Signatures
(in reply to aerialimage)
       Post #: 5088
RE: Anyone own a Warhead - 4/30/2006 5:43 PM
DadtoaMarine
Score: 100
Status: offline
Did you ask them why the hell it took a month to get your truck back? If it was any other company I would be worried that they were waiting for the warranty to run out before returning your truck.
Hide Signatures
       Post #: 5089
RE: Anyone own a Warhead - 4/30/2006 5:59 PM
aerialimage
Score: 100
Status: offline
Sort of figured it out on my own! I called to check status after about 3 weeks! Turns out they were waiting for a back ordered engine mount to come in before sending my complete package back!
When I purchased the truck it had a broken engine mount out of the box never even fueled it!
So I had purchased a new mount and installed it!
My mistake was sending in the old broken mount and a servo saver set that I broke along with the truck! even though they were simply replacement parts they seem to like to wait until all items are filled then send everything back together! Even after a month I was still happy with what they did, Just to bad the truck only started 1 time after return!
Now it is on the shelf waiting for a new pull start and also a carb as it was still running rich on the full tank and lean on the low tank! I think it was better after they adjusted things but Really 1 tank was not enough to really find out much! They really are trying to get the Warheads all sorted out And I really like a company that gives a good effort!
No complaints here!
Hide Signatures
       Post #: 5090
RE: Anyone own a Warhead - 4/30/2006 6:04 PM
aerialimage
Score: 100
Status: offline
Oh on the Heli! They are not nearly as cheap to fix!
I will try and be very careful after I fix it!
IT was the same old story, I know everyone else has alot of trouble flying these but I will do a little better as I fly real airplanes and therefore must really understand the characteristics of flight a little better!
And then there was the hover, it was all going fine so I will have to go just a little more Yup first real take off there she goes! Well you know the story from there!
1 crash, $70 15 seconds of fun! And yes of coarse the landing gear training set was allready ordered ( it came in 1 day late)
Back to trucks!
Hide Signatures
       Post #: 5091
RE: Anyone own a Warhead - 4/30/2006 8:48 PM
JFACKY
Score: 100
Last Login: 10/21/2012
Status: offline
To the guys having problems with the servos moving when they turn off thier trucks, the proper way to turn off the radio system to avoid servo glitching, is turn off the reciever first then the radio. I have never had a problem with flooding because the servo opened the carb when as the radio was shut off.
HTH
JIM
GP UltraSport 40+, GP Escapade EP, NexStar.46, TF Corsair .60, Warhead, ThunderShot,MRC/Academy SB Sport pro kit
Hide Signatures
       Post #: 5092
RE: Anyone own a Warhead - 4/30/2006 11:55 PM
ashburg
Score: 110
Last Login: 1/26/2013
Status: offline
I'll let you know soon...it should be here tomorrow, but I probably will sit it on the counter for a week like I typically, ritualistically do with my new trucks
quote:
ORIGINAL: ggomez
Take it easy,
Gil
Savage, Warhead, and Revo tip & trick compilations at www.ashburg.com
Hide Signatures
       Post #: 5093
RE: Anyone own a Warhead - 5/1/2006 1:51 AM
HPI4LIFE
Score: 100
Status: offline
I shipped it to them 2 weeks ago. It took ups more than a week to get it to them. In a e mail hobby services told me they would have it done middle of next week. I sent it to them for the radio gliching and the truck went on auto pilot and tumbled for quite a way. almost everything broke. I have a couple of pics hard to c all the damage.
Hide Signatures
       Post #: 5094
RE: Anyone own a Warhead - 5/1/2006 2:55 AM
Bill Plude
Score: 100
Status: offline
OK, ash , The only reason the Revo will be sitting "on the shelf" for a week, will be because it's going to take that long for you to figure out how to keep from hurting your face from smiling and telling everybody how easy it was to get it going, break it in, not have to spend a week tuning it, and how much better a machine it is compared to the SavageX LOL..........oh, and don't even bother to pull the carb off this one, trust me..........
Hide Signatures
       Post #: 5095
RE: Anyone own a Warhead - 5/1/2006 3:49 AM
ashburg
Score: 110
Status: offline
LOL Yep...got back from the "races", beat up the Savage (I'll give a damage report on the Savage X thread), all the other guys were driving Revos...even the old beat up Revos hold together...and WIN. Ah the pictures I will be taking, petting it and patting it and calling it George
Hide Signatures
       Post #: 5096
RE: Anyone own a Warhead - 5/1/2006 4:12 AM
spv1425
Score: 100
Last Login: 7/23/2009
Status: offline
I'm anxious to hear about the Revo 3.3. Just came back from a weekend on block island, RI. Spent most of the time running my Warhead and my SavageX. The Warhead was running strong till I hit a rock wall, broken servo saver as usual. Started up the Savage X and lost a front left wheel nut All better after a quick run to the hardware store. Warhead was running great, temps around 230, fast as heck. Then was blasting down the road and ran over a piece of asphalt, got caught up in the back wheel for a second and broken the rear shock tower. SavageX ran flawlessly all weekend. The Warhead does handle better than the Savage X, doesn't flip over as easy. I can power slides on pavement without flipping it.
Duratrax Warhead
Savage X
Hide Signatures
(in reply to ashburg)
       Post #: 5097
RE: Anyone own a Warhead - 5/1/2006 4:25 AM
ashburg
Score: 110
Status: offline
but but...all you have to DO to get the Savage to handle better is to lower it with some suspension limiters like zip ties and throw on some wider tires. If you really want to get radical, you can put extended A arms on there
quote:
ORIGINAL: spv1425
Hide Signatures
(in reply to spv1425)
       Post #: 5098
RE: Anyone own a Warhead - 5/1/2006 4:36 AM
spv1425
Score: 100
Status: offline
Sorry Ash, should have said a stock savage X and a stock Warhead. I haven't really upgraded either too much yet. I wanted to run the heck out of the stock engines before upgrading and figured if I screwed the engines up no big loss. Both are great trucks but the SavageX is much tougher hands down. I've never seen the Warhead do cartwheels without breaking something. The Savage takes a beating and comes back for more.
Duratrax Warhead
Savage X
Hide Signatures
       Post #: 5099
RE: Anyone own a Warhead - 5/1/2006 4:40 AM
Bill Plude
Score: 100
Status: offline
and replace the anal probe and searching for the cavity to put it in with a simple box to start it with that also replaces the glow starter. Forget how to seal your engines too. Can't wait can you ash? You still think it'll be sitting long? LOL get the 7.2 battery charged, don't need a hump pack, theres a hole under the truck where you just plug in.
Hide Signatures
       Post #: 5100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.812RCU1
