RE: Anyone own a Warhead
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Warhead RTR
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> RE: Anyone own a Warhead
    Page: <<   < prev  20 21 [22] 23 24 25 26 27 28 29   next >   >>
    Login
    RE: Anyone own a Warhead - 1/18/2006 8:09:10 PM
    spacoli
    Status: offline
    From what I read you got it right. The carb slide has to be open while turning the LSN in all the way till it stops, then back it out 12 1/2.
    _____________________________
    Hey bud what's your problem.....all I need is a cool buzz and some tasty nitro
    (in reply to bamaman98)
           Post #: 526
    RE: Anyone own a Warhead - 1/18/2006 8:30:38 PM
    spacoli
    Status: offline
    Spaccoli (or anyone)...where is this carb leak you're talking about, what's the fix for it, and how do you remove the carb? I took of that set screw that appeared to be holding the carb on, but it didn't release it...obviously a pin there, but how to get it out?????
    Do a bubble test first to see if you have a leak.
    Just tap on "set screw" (pinch bolt) on the end with the bolt, it will move , just takes a tap. Once it's loose try to make both sides of the pinch bolt even on each side in relation to the hole it's in. This will keep the curved part of the pin somewhat centered with the carb throat. Start roating carb back and forth while pulling up. Just be careful, there is a lower o-ring that can get caught on the pinch bolt and get damaged.
    I think I damaged mine the first time I pulled the carb. the lasts time went good.
    There is two o rings, I would say the top one is the most important one. I moved my one good o-ring down to the lower groove and bought on a little fatter 0-ring that the stock for the carb base.
    I oiled it up and slid back into engine, compressed the fatter o-ring slightly asnd tighten.
    Seal up the pinch bolts of both sides and your done.
    Let sealant set up and do a bubble test to look for leaks.
    (in reply to ashburg)
           Post #: 527
    RE: Anyone own a Warhead - 1/18/2006 8:58:03 PM
    spacoli
    Status: offline
    Just received an email from Sullivan Products maker of tiger drive. They have a drive that will fit the engine but it hits the engine mount.
    E-mail reply:
    "We have one that will fit the engine (TigerDrive S681) fine but it turns out it interferes with the engine mount. If you are willing to modify the Tigerdrive you probably can get it mounted. Attached are some pictures that a customer sent us of the interference. Hope this helps."
    Regards,
    Kevin Peryea
    Sullivan Products
    Check out the pictures. I include some pictures of the underside of the engine mount, you can see where the standard pull start sets in relation to the other pictures.
    It's way off the mounts. Not sure if it's doable with any mods. I don't know how you would modify the tiger drive.
    I'm sure they will come out with one that works.
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    (in reply to FE_Chris)
           Post #: 528
    RE: Anyone own a Warhead - 1/18/2006 9:06:58 PM
    bluestratos
    Status: offline
    I bought the tiger drive from towerhobbies last week, tore the truck apart to get the engine out only to find out that the one way bearing is way to big for the shaft on the rear of the engine :-( Am I missing something? The one way bearing that was on the engine has a much smaller hole I would guess about a 5 mm.. I believe the one I got has a 8 mm hole.
    (in reply to spacoli)
           Post #: 529
    RE: Anyone own a Warhead - 1/18/2006 9:44:33 PM
    bamaman98
    Status: offline
    This may sound odd but can someone post a pic of the spur gear and spring installed and also the pic of the LSN from above with the carb closed. Something just doesn't seem right and pics for me are GOOD. I would post mine but I don't have a dig cam. Thanks!
    (in reply to bluestratos)
           Post #: 530
    RE: Anyone own a Warhead - 1/18/2006 9:46:55 PM
    spacoli
    Status: offline
    TigerDrive S681 drive does have a 8mm bearing. I guess the guy that sent me the email made a mistake. Oh well there's no way it will work.
    < Message edited by spacoli -- 1/19/2006 8:04:23 PM >
           Post #: 531
    RE: Anyone own a Warhead - 1/18/2006 9:57:24 PM
    spacoli
    Status: offline
    This is easy mine is all apart.
    Hope this is what you want.
    If not let know, I will snap some more.
    quote:
    ORIGINAL: bamaman98
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
           Post #: 532
    RE: Anyone own a Warhead - 1/18/2006 10:07:22 PM
    bamaman98
    Status: offline
    Your my best friend. Thats perfect!!!
    Thanks a ton
           Post #: 533
    RE: Anyone own a Warhead - 1/18/2006 10:16:36 PM
