RE: Anyone own a Warhead?
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Warhead RTR
  • 1 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> RE: Anyone own a Warhead?
    Page: <<   < prev  471 472 [473] 474 475 476 477 478 479 480   next >   >>
    Login
    RE: ... - 4/29/2008 11:26:15 AM
    rcbeep73
    Status: offline
    quote:
    ORIGINAL: Extreme Crash
    I posted a bit ago about installing the race steering kit. I got some longer screws and installed the kit. I'm still working on setting the toe adjustment. What's the best way to do this and should I set the toe in or out? One more question, What would be a good replacement servo for the steering be? I know it needs more torgue but what would work well with this vehicle?
    to set the steering up right you should have a little toe in. but if you want more steering in the turns have them toe out. as for the steering servo this is what i use check out the link from tower. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXUZ89&P=ML
    hitec 32645S for only $31.99 it's a good strong servo.
    (in reply to Extreme Crash)
           Post #: 11801
    RE: ... - 4/29/2008 3:38:37 PM
    rcbeep73
    Status: offline
    so tell me guys what do you think of the wheels and tires.
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    Click for fullsize
    (in reply to davido666)
           Post #: 11802
    RE: ... - 4/29/2008 3:41:03 PM
    micahs
    Status: offline
    I think they look pretty cool. Look like they weigh a lot less!
    (in reply to rcbeep73)
           Post #: 11803
    RE: ... - 4/29/2008 3:44:56 PM
    rcbeep73
    Status: offline
    quote:
    ORIGINAL: micahs
    Thanks, yes alot but i did not weigh them so not sure by how much.
    (in reply to micahs)
           Post #: 11804
    RE: ... - 4/30/2008 3:48:19 AM
    micahs
    Status: offline
    Alright, need some help. finally got my warhead running good but the sterring is f'd up. I installed the racing steering kit and ever since it doesn't steer well. I 180'd the steering link (angled facing forward) and attached the steering rod to the top of the wheel hub link and the bottom of the steering link. It doesn't turn well at all especially to the left. I know I'm doing something wrong but can't figure it out. does anyone know where to download a pic. diagram or something?
           Post #: 11805
    RE: ... - 4/30/2008 4:23:34 AM
    keeblerelf
    Status: offline
    quote:
    ORIGINAL: micahs
    I'm pretty sure it goes on the bottom of the wheel hub link. I originally put mine on the top to reduce the extreme angle that you get, but when you compress the shocks, the wheels toe out from each other. I installed it on the bottom, and it all worked fine other than the fact that the rod end rubbed on the hub due to that extreme angle that I was trying to avoid in the first place. This rub doesn't allow the full range of steering and is incredibly annoying. Anyone know a fix for this?
           Post #: 11806
    RE: ... - 4/30/2008 12:40:57 PM
    rcbeep73
    Status: offline
    quote:
    ORIGINAL: keeblerelf
    quote:
    ORIGINAL: micahs
    try this, put a bigger wheel hex on to push the wheel out on the hub. this should give more room for the links. i just installed different wheels that has a different off set and the linkgs dont hit anymore. let us know what you do.
    (in reply to keeblerelf)
           Post #: 11807
    RE: ... - 4/30/2008 1:49:20 PM
    rcbeep73
    Status: offline
    well i have good news and more good news, the new wheels and tires are great. they don't rub the steering links and my steering is faster. the truck gets up to speed much faster and it shifts sooner too. the tires did a good job of cutting the lawn for me lol. i don't know about you guys but when i put the aluminum steering on i was breaking steering servo horn so what i did was put on a heavy duty servo saver from sassy chassis ( old stock that i had ) and tighten up the steering servo saver and i don't break anymore horns. look at the picture to see the servo saver. i had to shim out the servo about 1mm to make it work. like i said it's a big servo saver.
    Click for fullsize
           Post #: 11808
    RE: Anyone own a Warhead - 4/30/2008 4:05:48 PM
    nzmagoo
    Status: offline
    Hi I've recently got a warhead evo and have been having heaps of fun with it until my mate drove it into a tree at full noise..... nothing a hammer and some time couldnt fix lol.. The only problem iv'v had is that the roto start broke a screw then stripped the bevel gear and totally destroyed its self.. After going to the lhs they aren't very keen on helping as they dont sell duratrax cars... so my question is what other roto starts or pull starts can fit on the super engine.. Oh thanks to all the guys on here there is so much stuff that has been very helpful for a total novice,and save me from learning the hard way..
    (in reply to 86atrack4)
