RE: Anyone own a Warhead?
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Warhead RTR
  • 2 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> RE: Anyone own a Warhead?
    Page: <<   < prev  478 479 [480] 481 482 483 484 485 486 487   next >   >>
    Login
    RE: ... - 6/3/2008 2:43:42 AM
    jbb
    Status: offline
    also make sure u are getting the correct gear mesh i only run plastic spurs because i dont like the metal
    _____________________________
    warhead evo love it (needs servo)/just got my aftershock!!!
    (in reply to rcbeep73)
           Post #: 11976
    RE: ... - 6/3/2008 3:24:52 AM
    wired-123
    Status: offline
    what dont you like about the metal, it seams like it would be better or does it stress other parts too much
    (in reply to jbb)
           Post #: 11977
    RE: ... - 6/3/2008 4:09:44 AM
    davido666
    Status: offline
    I have two warheads. One with the metal gear and one with the plastic one. The metal gears hold up a long time. I have had the same gear on my truck for a long time. Just remember if you get the upgrade metal spur make sure you use red loctite on the six screws that holds the spur gear together. Are you stripping the plastic spur gears or metlting them. If you clutch bell gets to hot it will melt the gears in one are. If you are stripping the teeth all around the gear you need to make sure the motor mount is not cracked and check all the screws that hold the motor mount in and the engine screws. Make sure your clutch bell bearings are not wearing out. If the are starting to go they will heat up the clutch bell and melt the spur gear. I have the same plastic one on the other truck and it is still holding up. Make sure the mesh is set correct.
    I love the smell of nitro in the morning!
    Warhead with axial 32 and HT pipe, Raze, himoto 1/10th, Firehammer MT clone.
    (in reply to wired-123)
           Post #: 11978
    RE: ... - 6/3/2008 10:42:41 AM
    rcbeep73
    Status: offline
    quote:
    ORIGINAL: wired-123
    do as davido666 said it's good advice.
    I know some people don't like a metal gear as if a small stone gets in there it might break something more other then the gear. I have seen it happen but I think the warhead benefits having a steel spur. But you still have to make sure you adj your bell and spur as per the instruction in your manual. Just cause it’s metal does not mean it cant strip or damage your clutch bell. I don’t know what engine you have but with a bigger faster engine go with the metal set up.
    You will hear from both sides of the fence about this but this is my opinion only. Let us know what you do.
           Post #: 11979
    RE: ... - 6/4/2008 4:39:43 AM
    jbb
    Status: offline
    i dont like the metal spur cuz i would rater blow a spur than a pin in the tranny and take it apart imo
           Post #: 11980
    RE: ... - 6/5/2008 12:44:41 AM
    wired-123
    Status: offline
    going to put one more plastic spur on checked the motor mount and was missing a screw, replaced it loctited all of them again mesh looks right will see what happens if I strip it gonna go with metal.and for the motor still the super pooper in both but imo its fine had no problems with them of course havent ran the newest one much.
    (in reply to jbb)
           Post #: 11981
    RE: ... - 6/5/2008 1:40:47 AM
    jbb
    Status: offline
    if u do start having problems with them seal them
           Post #: 11982
    RE: ... - 6/6/2008 4:16:31 AM
    wired-123
    Status: offline
    stripped it too! but this time E-clip came off clutch bell ruined the clutch bearings/or bearings went out first dont know but either way one more trip to LHS tom. so maybe I can get them running good enough to do some bashing this weakend. thanks for all the hints/ideals.
    Happy Bashing
    (in reply to jbb)
           Post #: 11983
    RE: ... - 6/6/2008 6:39:39 PM
    davido666
    Status: offline
    quote:
    ORIGINAL: wired-123
    Happy Bashing
    I had the same problem with the ering coming off. I had another supper pooper from a raze buggy and I put that engine in with the sg shaft. It works better because it uses a screw to hold the bell on. A much better method.
