davido666
Joined: 4/17/2006 From: London, ON, CANADA Status: offline
I have two warheads. One with the metal gear and one with the plastic one. The metal gears hold up a long time. I have had the same gear on my truck for a long time. Just remember if you get the upgrade metal spur make sure you use red loctite on the six screws that holds the spur gear together. Are you stripping the plastic spur gears or metlting them. If you clutch bell gets to hot it will melt the gears in one are. If you are stripping the teeth all around the gear you need to make sure the motor mount is not cracked and check all the screws that hold the motor mount in and the engine screws. Make sure your clutch bell bearings are not wearing out. If the are starting to go they will heat up the clutch bell and melt the spur gear. I have the same plastic one on the other truck and it is still holding up. Make sure the mesh is set correct.
_____________________________
I love the smell of nitro in the morning! Warhead with axial 32 and HT pipe, Raze, himoto 1/10th, Firehammer MT clone.
