RE: Anyone own a Warhead?
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Warhead RTR
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> RE: Anyone own a Warhead?
    Page: <<   < prev  480 481 482 483 [484] 485 486 487 488 489   next >   >>
    Login
    RE: ... - 8/24/2008 10:55:06 PM
    davido666
    Status: offline
    I put in an axial 32 motor. All you need to do it is a Ofna shim kit, sg nut (I used the duratrax raze one), reuse the fly wheel and collet off the old motor. The carb has to be turn around 180 plus a little to clear the spur gear. I filed off a little of the tanny support to clear the screw on the end of the sg shaft. I also bought 2 non flange clutch bell bearings (5x10) for the bell. Any large block motor will fit. The Axial motors carb has to be turned a little strange to clear the spur gear but it works. Other motors may not have this problem. My axial uses a pull start whick is better because I no longer have to carry around the started and remember to charge it. I would recommend using a pull start engine and get a team associate primer ball for the fuel line.
    _____________________________
    I love the smell of nitro in the morning!
    Warhead with axial 32 and HT pipe, Raze, himoto 1/10th, Firehammer MT clone.
    (in reply to Honda10121)
           Post #: 12076
    RE: ... - 8/24/2008 11:13:50 PM
    rcbeep73
    Status: offline
    that is a great engine to use and i think i will be putting in the same. i use a k4.6 hpi enigne with roto start. if you do use a engine with a roto start you will need to grind down the egnine mount just a hair. it's realy no big deal to do. a pull start will work just as good. besides if the engine is tune right it should start on the fist or sec pull. i do not reccomend the axial 28 spec 1 RR. i have that in my savage and i am buring up clutches. you just need a good monster truck engine. another is the lrp 3 monster truck engine. this engine is great and the power and speed are great.
    (in reply to davido666)
           Post #: 12077
    RE: ... - 8/25/2008 12:18:36 AM
    Honda10121
    Status: offline
    wats the primer ball you were talking about i always just blow in the fuel tube
           Post #: 12078
    RE: ... - 8/25/2008 12:25:45 AM
    rcbeep73
    Status: offline
    i think he is talking about this http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFUD3&P=7
    i myself don't use one but they are handy to use.
           Post #: 12079
    RE: ... - 8/25/2008 12:56:21 AM
    schlags62
    Status: offline
    I run a LRP in one of my WH's............awesome!!!!
    Go BIG or go home! 110%
    (in reply to rcbeep73)
           Post #: 12080
    RE: ... - 8/25/2008 10:10:50 PM
    davido666
    Status: offline
    quote:
    ORIGINAL: Honda10121
    Here it is.
    Greatest thing since sliced bread. Make starting the engine so easy. And if I don't use all the fuel in the tank then I can pump it out with this back into the fuel bottle.
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
           Post #: 12081
    RE: ... - 8/25/2008 10:14:19 PM
    rcbeep73
    Status: offline
    quote:
    ORIGINAL: schlags62
    any problems running that engine in your warhead? do you have the foc intalled? i am thinking of using a bigger engine in mine.
    (in reply to schlags62)
           Post #: 12082
    RE: ... - 8/25/2008 10:57:37 PM
    Honda10121
    Status: offline
    is there any other good upgrades besides race steering and new motor
           Post #: 12083
    RE: ... - 8/25/2008 11:01:49 PM
    rcbeep73
    Status: offline
    well you can change your rims and tires, you might want to install the aluminum servo saver assy. that helps alot. i know the stock plastic breaks alot.
