RE: Evolution 46
Tower Hobbies
Logged in as Guest
  Printable Version
TurboHeader Muffler for Saito's
Seller:  RC Specialties
Details:   $49.95   |  10/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Evolution 46
Page: <<   < prev  1 2 [3]
Login
RE: Evolution 46 - 4/20/2006 4:26:43 AM
blw
Status: offline
bmarks,
What plug do you use now?
_____________________________
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
(in reply to w8ye)
       Post #: 51
RE: Evolution 46 - 4/21/2006 2:08:06 PM
DarZeelon
Status: offline
quote:
ORIGINAL: blw
Something that W8YE suggested for my 46NT- try either the OS A3, or Tower plug if you are using an OS 8. That was a world of improvement in my engine. I'll never go back to the OS 8.
Barry,
The right plug range for this engine is medium heat. The OS A3 is too hot and you need to adjust the engine significantly richer to avert detonation (what a lean-run really is).
This would make the OS #8, Enya #4, Rossi R4, Novarossi/MVVS C6-S, K&B-1L, the newer Tower and other plugs suitable.
The OS #8 has been changed lately and not for the better... Sigrun mentioned this in two recent threads.
He says they are only like the older OS #8 in their appearance, but are lousy from every other aspect...
< Message edited by DarZeelon -- 4/21/2006 2:11:01 PM >
Dar Zeelon - ISRAEL - ddzeelon@gmail.com
MVVS - Jett - Nelson - Bolly - Mejzlik
(in reply to blw)
       Post #: 52
RE: Evolution 46 - 4/21/2006 4:52:01 PM
bmarks
Status: offline
Hanger 9 3001.
This is the plug that came with engine.
Brian
(in reply to blw)
       Post #: 53
RE: Evolution 46 - 4/21/2006 8:04:10 PM
w8ye
Status: online
Dar,
As you well know, there are many variables in running a model airplane engine. That's why the engines have needle valves and there are many different glow plug, fuel, and prop manufacturers.
Before anyone makes any quotations, it would be best for them to take these many variables into consideration.
You were not standing beside the engine with BLW and me the day that the OS #3 recomendation was given. If you were, then I'm sure you would have had the same recomendation as I did. Especially if that was the alternative you had in your flight box. Also considering that the engine then ran well with no pinging and it also ran well again yesterday when the temperature was 86 degrees...
There may be a time in BLW's future that he has to use a different plug than the #3? But the #8 was far too cold for his engine that day.
Enjoy,
Jim
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to bmarks)
       Post #: 54
RE: Evolution 46 - 4/21/2006 9:11:05 PM
DarZeelon
Status: offline
Jim,
I give some of my recommendations, from engine type and construction.
This specific engine is made (as I was told) by Sanye, like Magnum, ASP and SC engines and has the same general construction.
It was also tested by the leading R/C magazines and found to be similar in power to the OS FX and to similar engines.
I don't think this engine should differ from them by any large degree, in its ignition needs and by the book, it would seem the OS #8 and other medium heat plugs should be suitable for it.
It could be, however, that in the interest of easier operation, the manufacturer changed to a lower compression ratio.
This would require a hotter glow-plug.
The situation would be so, if the engine cannot be leaned down enough, so as not to lose much RPM when the glow driver is removed.
If an unreasonable RPM loss is persistent with a new plug, known to be good, a hotter grade plug is needed.
The 10-30% nitro recommendation (more than OS and other Sanye engines) seems to be coherent with this assumption.
The only recommended plug is the H9 Super Plug, which does not feature a heat range... See photo.
The setting of the needle valves is the last variable...
It is adjusted after the manufacturer determined the suitable load (prop size), nitro percentage and set the compression ratio.
This is the last thing that is adjusted, so the engine would run at its best, with the given constants.
The fact that with plug 'X' an engine CAN be adjusted to run, without detonating and without losing RPM on removal of the glow-driver, does not make this plug right. It could be the mixture is adjusted richer than ideal, to avert detonation, since the plug is too hot.
The engine would then become too rich in the mid-range...
This problem affects many because everybody is using the cheap A3...
Click to see fullsize image.
Click for fullsize
(in reply to w8ye)
       Post #: 55
RE: Evolution 46 - 4/21/2006 9:20:55 PM
bmarks
Status: offline
Great info on glow plugs for a novice. My specific problem is the engine not running properly, but when I flip start it the engine runs clockwise more often than counterclockwise. Is this related to heat range of plug?
Brian
(in reply to DarZeelon)
       Post #: 56
RE: Evolution 46 - 4/21/2006 9:29:26 PM
proptop
Status: offline
It could be a little too rich?
Best way to cure that is with an electric starter...
FWIW I currently have a "hot" Fireball in mine...inverted in the Cermark Bobcat. Runs fantastic(ly?) in this weather anyway...(mid 60's spring temps, 10% nitro, 10X7 APC )
Mine has had the H9 (looks like a 4 stroke ) plug, an O.S. #8 and type F, a Fox "Miracle" and Fox std. long, and probably a few others...
Best out of those are the H9 plug that came in the engine, and this Fireball...
It's bad luck to be superstitious...
Revver Bro #77
       Post #: 57
RE: Evolution 46 - 4/21/2006 9:39:08 PM
DarZeelon
Status: offline
No, Brian.
This is usually the result of over-priming. Reduce the priming to 1-2 revolutions.
When you want to flip start your engine, first of all, mount the two-blade prop on the shaft so it is level; parallel to the wings, when compression is encountered.
Now, master back-flip bump-starting!
Don't flip the prop counter-clock-wise over compression. In stead, bump it sharply clock-wise, against compression, while 'soft-fingering' the blade's leading edge, so your finger(s) will slip away from the advancing blade.
It will most likely fire, if the prime is right and start in the normal direction.
It works and you are less likely to hurt yourself doing it so.
       Post #: 58
RE: Evolution 46 - 4/21/2006 9:50:41 PM
bmarks
Status: offline
I'll try these suggestions over weekend.
Brian
       Post #: 59
RE: Evolution 46 - 4/22/2006 3:23:56 AM
blw
Status: offline
Both of my Evolution engines are easy to start. I have run the .45 and .46 a lot. The noticable problem is that once started the crankcases seemed loaded and they wouldn't run smoothly until the throttle was massaged and wide open achieved. This took time.
The .45 is simply a hot engine that puts out a lot of power when the flywheel weight is removed and something along the lines of a 11x7 prop is used. The engine that I have has more than a hundred flights without a deadstick, except for 2 when there was trash in the needle valve. It just wants to run and doesn't care how you run it.
The .46NT replaced an OS .46FX. That replaced a TT Pro .46. I don't recall breaking in the .46NT. I did run it a couple of minutes before putting it on the same plane. I got some comments on my first takeoff run about how much more power the Evo seemed to have over the .46FX. This was with the OS 8 plug and the engine developed more power after a few tanks of fuel.
I'm not a 3D flyer, but there are a lot of Somethin Extras at my club and those guys do hover. The .46NT is on a SE and being that I once flew helicopters I sometimes feel like I should at least give it a try for grins. Before changing from the OS 8 to the Towers plug I could sustain hover power at 75% throttle. It is now less than half throttle with the Towers plug. That is all that changed. Same Omega 15% fuel, same APC 12.25x3.75 prop. I could not take off and pull vertical and accelerate with the #8 but I can now. Well, I did put a Towers muffler on the engine and not on the OS or TT. The Towers plug made much more difference in performance. Yes, I did have to tune the HS needle valve, but I hadn't flown the engine since cold weather and can't comment more on that.
I keep forgetting to drag out the RCMs with the .45 and .46 teardown and review. I think both were by Clarence Lee. I don't recall any comments about lower compressions but I will find them and see. I've searched a couple of other places and compression isn't mentioned. I would be surprised if this were true. These engines are well made, well designed, and a great bargain considering they are chromed. They are not cheap knockoffs.
       Post #: 60
RE: Evolution 46 - 4/23/2006 1:30:31 AM
blw
Status: offline
The .46NT was tested by Clarence Lee in RCM magazine and he said that compression is 7.7:1.
(in reply to blw)
       Post #: 61
RE: Evolution 46 - 4/23/2006 2:42:21 AM
downunder
Status: offline
quote:
ORIGINAL: blw
CL references his compressions from where the exhaust port closes. The geometric compression is more likely to be around 10:1 which is pretty much standard for most sport engines. There are arguments either way as to which is more correct but CL seems to be in the minority with his way.
(in reply to blw)
       Post #: 62
RE: Evolution 46 - 4/23/2006 2:45:43 AM
blw
Status: offline
Yes, he does state how he figured it. At least he explains that.
Kinda interesting how you can convert the .40 Alpha to either a .45 or .46.
(in reply to downunder)
       Post #: 63
RE: Evolution 46 - 4/23/2006 4:29:05 AM
ugdrummer08
Status: offline
How does the Evo .46 run on an Ultra Stick? I'm considering this plane for my second plane and I am trying to find a good engine. I am considering this one, the O.S. .46AX, the Thunder Tiger Pro .46, and the Megatech .46 (I already own a Megatech .46, and it's not bad at all for the price). So my question, is the Evo a suitable choice, or should I go with one of the others?
(in reply to w8ye)
