dreadnaut -> RE: Tips And Tricks for CAD Programs. (2/10/2007 10:28 PM)
quote:
ORIGINAL: Skinny Bob Mike, I have AutoCAD, Solid Works etc, but find the learning curve a bit much. ... SolidWorks has one of the best included tutorials I have seen. A lot of people swear at AutoCAD. I swear by it. The key to learning ACAD is to keep an eye on the command prompt at the bottom of the screen. Drag it up so that 3 lines are displayed above the command: ''OH NO!!! I have to learn COMMANDS!?!?!?!?!?'' Not a problem. If you want to draw a line, type ''LINE''. Want to draw a circle? Type ''CIRCLE''. I have heard it said, here in RCU, and elsewhere, that ACAD is not intuitive. I can only scratch my head at that. Here is a key to understanding some command line notation. If ,for example, you type line, you will be prompted to enter points after you have done a couple of segments, you will get OPTIONS after the prompt; [Close/Undo]. The square brackets denote options. Pay attention to the capitalization. You can invoke the option by pressing the capitalized letter, then enter. Pay attention because some of the more advanced commands have lots of options, and the shortcut is often a letter (or letters) capitalized in the middle of a word. Here is an example Command: cs UCS Current ucs name: *WORLD* Enter an option [New/Move/orthoGraphic/Prev/Restore/Save/Del/Apply/?/World] Another convention is angle brackets <>. Some commands requre you to input a numerical value, like the radius of a circle. If you draw another circle you wil be shown a DEFAULT in angle brackets after you enter the center. In the case of a circle, the last value for radius that you entered will be displayed like this; <3.0000>. If you want to repeat this, simply press enter to accept the default. This can be very useful for drawing a set of motor mounting holes. You only need to type the radius once.
